Decided to give this a go mate, due tomorrow so will let you knowMAJORITY D80 ? have hdmi ARC and are just £99
Thanks for the recommendation.Decided to give this a go mate, due tomorrow so will let you knowMAJORITY D80 ? have hdmi ARC and are just £99
Thanks for the recommendation.Enjoy! Really happy with mine!
They’ve not told you that you have to finish putting it together. You’ll find the screws and necessary tools inside. Good luck
Still need to do mine...No, I had to upgrade the firmware, it's an easy process.
Yeah, you'll need to have it hooked up to the PC to apply the firmwareDo you have to use the usb at the back to update the firmware, mines still in the box as I've been busy today and still need to box up my old monitor.
Fingers crossed it works outDecided to give this a go mate, due tomorrow so will let you knowThanks for the recommendation.
Dude, it's not going to blow-up if you don't do it ASAPOMFG now you knowon the dell support page it does list the firmware update as critical so it's probably best to do it sooner rather than later.
It's the next update I'm looking for, which will hopefully sort the Dolby Vision issue.I updated the firmware yesterday after I dug the usb cable out of the box, on the dell support page it does list the firmware update as critical so it's probably best to do it sooner rather than later.
Are you running the cables from the port out the channel at the back before putting the cover on?Sorted out now and running great so much difference from my old one,had a bit of a heart attack moment as the power cable wasnt seated right because of the cover so ive taking it off.
, and during one match I had some pretty thick lines appear for second or two, haven't seen it since and I played Yakuza 0 for couple hours afterwards with no issues so thinking must've been a graphical issue in BFIt definitely helps, had a few games on R6 and some Fortnite and I was racking up some kills haha!Was playing BF1 last night, off topic but was bloody great match maybe the 240hz is making me better, and during one match I had some pretty thick lines appear for second or two, haven't seen it since and I played Yakuza 0 for couple hours afterwards with no issues so thinking must've been a graphical issue in BF
I've only tried BF1, I did buy MW3 but while installing it I was like wtf have I done and refunded it hahaha, I wish there was another FPS I could get intoIt definitely helps, had a few games on R6 and some Fortnite and I was racking up some kills haha!
