- 29 Aug 2010
- Cornwall
I didn't know it doesn't fit in the top of the 5000D, i want the 4000D, the 5000D is too large, is it the thickness of the rad that's the problem? I mean its thicker than typical CLC's but it can't be any thicker than a proper open loop rad, can it?
Yeah, it's the thickness that causes the issue. I've got the H110i in there at the minute and there's about 5mm clearance (just eyeballing it) to the top of the motherboard (Asus TUF Gaming B650-Plus, which has heatsinks right near the top edge, plus power connectors) and that's a 27mm thick rad.Length ways the 5000D is good for 320mm in the top.
Corsair 5000D Airflow Tempered Glass Mid-Tower - Black CC-9011210-WW
Order Corsair 5000D Airflow Tempered Glass Mid-Tower - Black CC-9011210-WW now online and benefit from fast delivery.www.overclockers.co.uk
The 4000D is 280mm
Corsair 4000D Airflow Mid-Tower Case - Black Tempered Glass (CC-9011200-WW)
Order Corsair 4000D Airflow Mid-Tower Case - Black Tempered Glass (CC-9011200-WW) now online and benefit from fast delivery.www.overclockers.co.uk
I think some people have done it by mounting the fans in a pull config outside the case (although still covered by the removable grate on the top), but again I'm not so keen on this solution.
The 120mm rad variants might be a little better, but I don't think so with this motherboard.
