lol, I absolutely rushed to get my order in......Then I posted it over at HotUKDeals.
I kept wondering if it would turn up, too good to be true, lol.
Considering some thinner fans to get my III 280 mounted in the roof of my case. Do we think I'd lose much performance if I mounted it with Jonsbo HF1415s in place of the stock Arctic P14s? The Jonsbo fans are 15mm thick instead of the 27mm that the stock ones measure.
Given rads need a good static pressure I would be concerned about thinner fans as that is a key area they lose put on. I think one of the AF III reviews mentioned higher fin density on the new model as well. So best to compare static pressure specs at the very least.
Installed mine over the weekend and really happy with it.
@w00dy85 Are you controlling your fans individually and if so what do they scale up to, in RPM..?
Looks very nice.
Looks nice. Is yours the 360 or 420? Also how are you finding the noise levels as I’ve seen a few posts over on Reddit claiming the these are a fair bit noisier than the LF2?
