- 17 Oct 2002
- Stoke
That's correct - you'd need to add a 3rd party MMI box to do Android Auto.Didn't think you could do Android Auto on ID6?
Anyone know decent place to get a replacement heated glass mirror for the drivers side (PN 51167186588)? Not spending £400+ from BMW lol
I have a feeling (could be wrong) that they're tied to the car, so if it was renewed in April 2023 then it'll expire a year later. I lost out a few months as my car was build around April 2020 but wasn't registered and purchased until September 2020. I contacted the dealer and was pretty much told there's nothing that can be doneGot an email saying some of my connected services are going to run out in April, is it normal from BMW not to give you a year as part of buying an AUC? Pretty sure Mercedes give you a year of all the services when buying an AUC. Makes good sense as it gives you a good chance to get to use the services and think if you can or cant do without
I may have one in my garage.
No, seriously. Will check tonight.
Let me know if you do mate.
Must NOT check.............. Bought mine New. Totally trying to ignore depreciation........ Got the Ultimate pack so that'll help...A tiny bitNope but just checked and my 21 plate M5 Comp is worth £1.5k more than I paid for it at a main dealer a month or so ago, so it looks like you are right seeing as it normally come in under main dealer prices
I do the service whatever comes first, the mileage or the dateCan someone verify something for me please?
I serviced my 2017 M240i June 2023 on around 54k miles. I had the following done:
- Engine oil service with microfilter
- Brake fluid service
- Vehicle check
I've just noticed that the service status in the car is saying the above are next due in 04/2024 but also in 4900 miles (car is near 59k miles). Can I assume the mileage takes precedence over the date? I assume so because when I got a quote for a service plan from BMW (I didn't go for it after all), their plan had stated the first (minor) service in June 2023 as I carried it out, and the next (major) in June 2025. Previous (major) service when spark plugs, air and pollen filters were changed was on 37k miles in 2021.
Why would it need doing again so soon? M240i IIRC is 2 yearly service intervals (or mileage based but nothing near 5k miles).Can someone verify something for me please?
- Vehicle check
What does the vehicle inspection comprise of? My M240i has just popped up saying it's due in March but also due in 3000 miles.Can someone verify something for me please?
- Vehicle check
That's why i thought it was odd that the display was showing 04/2024...My research in 2023 suggested it's every 2 years indeed. So i don't know if the garage manually set the next due date or if it is automatically chosen by the car.Why would it need doing again so soon? M240i IIRC is 2 yearly service intervals (or mileage based but nothing near 5k miles).
I normally would also do that but after just 5k miles seems too short an interval.I do the service whatever comes first, the mileage or the date
Are you sure it's not showing vehicle inspection? What does it show for engine service?That's why i thought it was odd that the display was showing 04/2024...My research in 2023 suggested it's every 2 years indeed. So i don't know if the garage manually set the next due date or if it is automatically chosen by the car.
