That looks incredibly disappointing, I don't know if I'll even bother eventually chucked a 5800X3D in next year over my 5700X, as it's not going to be 'that much' better than this 5700X3D
I only planned on doing it so I could chuck the 5700X into my 2nd machine a MITX, as it'd run nice and cool/quiet versus a 5800X/X3D... But I don't 'need' to upgrade either tbf, I just like giving the 2nd rig free upgrades, and makeswastingspending money easier
Hang on, the 5700X3D is 3GHz/4.1Turbo vs the 5700X 3.4GHz/4.6GHzwhy do they does this? Bit scummy
Wonder if I'll bother with a 5800X3D now, the 4070 is always at 96-100% so there doesn't seem to be a bottleneck, and everything I use it for is SP via tv/controller and easily plays anything at 4K dlss 60 capped for the 4k60 tv.
Some takeaways that are pro X3D from my above benchmarks:
- Cyberpunk GPU utilisation went from 96% to 99% with a 5 FPS increase
- TLOU GPU utilisation went from 95% to 100% with an 8 FPS increase
- The Shadow of the Tomb Raider benchmark showed CPU frames rendered etc went up massively, even though the final result was -1 FPS (margin of error and GPU limitation)
- Rise of the Tomb Raider had a weird minimum in Syria of 13 fps on the 5700X, while the minimum was 90 fps on the X3D - I wonder if the benchmark is wrong as the only noticeable drop is at the start of Geothermal Valley - possibly the drop is incorrectly attributed to the Syria part of the Benchmark
The temperature results and power utilisation baffle me. They're so much less in games compared with the 5700X, yet so much higher in Cinebench (can see the power utilisation goes up to 102W with the 5700X3D - proving it really is a 105W TDP chip like the 5800X3D).
I wouldn't be surprised if the biggest benefit from this upgrade is psychological. I was always wondering with my 5700X whether any drops I saw could have been avoided if I had an X3D chip. Plus I was also conscious of my sub-optimal RAM (3000 MHz CL15), which an X3D chip mitigates better than the non-X3D chips.
Time will tell if this upgrade is worth the £110+ cost (depending on the resale value of my 5700X). I'm guessing it wasn't in my case other than the psychological benefit of maxing out AM4 as mentioned above
