- 12 Feb 2006
- Surrey
does this game suffer from the same boring issue that valheim suffered with, which is that you have your starting area, you're weak, you go against weak enemies in this area, and to progress to stage 2, you need x material, and then when in stage 2, you get a little stronger, fight a little stronger enemies, but you can't progress to stage 3 until you've got x material, and then once you do, you progress to stage 4, get a little stronger, fight alittle stronger enemies, and to progress to stage 5 guess what you need, x material that's found in stage 4. rinse repeat.
and then to build the best base, you can't because the items you need are mixed within stage 2/3/4/5, and by the time you've hit stage 5 and got those cool items, there's nout left to do.
