Check the following two sites for loads of train and track options:-
https://joooooy.com/collections/tra...1&_sid=9119abbf4&_ss=r&variant=43483640463581
I ordered some track from YourWobb a while back for my Lad to use with his Lego train sets, all worked together without issue.Thanks for this.
Just ordered about £70 worth of track so hopefully it turns up and fits ok.
I checked eBay but not that much out there, and nothing going cheap really.
Mine is still boxed in the wardrobe. Scared to build it incase it yellows.Been decorating, realised the white plastic on my Saturn V has yellowed, looks terrible.![]()
Good lad! I'm still impressed by how solid the kit is. Took me about 8.5hrs with breaks to finish. Then a further couple of hours to fit the light kit.
Ah I see, I'll have to keep that in mind!Yes, it’s pretty normal, particularly if it gets direct sunlight.
Mines a slow process, I started at christmasGood lad! I'm still impressed by how solid the kit is. Took me about 8.5hrs with breaks to finish. Then a further couple of hours to fit the light kit.
I will say the Brixmaxx kit for the 9x8 isn't as good as the one for the RSR, no remote or customisability. Felt a bit ripped off considering it was the same price as the RSR light kit.
Dont get much free time to spend on it though. Got the RSR to build still alond with a few others.What's the best way to dispose of lego? Nobody's going to want a yellow Saturn V, do I just bin it, or is there a better way?
I would like a yellow Saturn V. I would pay postage if you want to recycle it to me? It would still be fun to build for me.What's the best way to dispose of lego? Nobody's going to want a yellow Saturn V, do I just bin it, or is there a better way?
ok dm meI would like a yellow Saturn V. I would pay postage if you want to recycle it to me? It would still be fun to build for me.
How does this stuff fare, quality and instructions wise?Back from a few days away and.had another package waiting
Can't wait to crack on with this one
