Man of Honour
- 23 Mar 2011
- West Side
Mite as well go kryonought.
I use noctua nt h2 paste... its decent and noctua says should last lifetime of cpu or repaste every 5 years.also have some arctic mx6 too.. same reason..long lasting
Almost done, I'm struggling with the central fan of the cooler, the clips just won't stay fastened...Did you finish build? All booted ok?
I have used that cooler before getting the Freezer III and had trouble with the front fan, took ages to get it just right.Almost done, I'm struggling with the central fan of the cooler, the clips just won't stay fastened...
Is there an on off switch on the rear of the power supply?All connected, it doesn't turn on and I don't know why...
Make sure you have the orientation of the front panel in the motherboard correct (super easy to get it upside down or whatever). You could try the reset switch too, for if you got them the wrong way around.Do you mean the psu switch? I turned it on of course. I suspect I'm not connecting properly the chassis panel to the motherboard but I don't know what I'm doing wrong
Thank you, I will check next weekend.Make sure you have the orientation of the front panel in the motherboard correct (super easy to get it upside down or whatever). You could try the reset switch too, for if you got them the wrong way around.
It might just be the camera angle but the first four pins on the ATX 24 pin look like there's a small gap between them and the motherboard.
2x16? Eh? Do you mean the 8-pin EPS 12v? If so then yes, you do need both.Also, does MB need BOTH 24pin ATX and 2x16pin ones?
Hmm. From the angle that you took the picture, the two pins are UP/DOWN, because if you follow the pins in the manual there's a line from the label that stops, if that makes sense. If I'm right, then I think you have them wrong, though I'm not sure if this would actually stop the PC booting because ground is uhm, ground.I'm also not sure if power and reset should be on top of each other or next to each other, not 100% clear on MB.
PWRSW is the first label and under the label there are two lines, the lines lead to the pin-1 and pin-2 (PWRBTN & GND). The lines stop at the pin. Is that clearer?Page 32, it's not really clear to me...
I wouldn't reseat the connector, I'd just push those first 4 pins (at the top of the board) down a bit to make sure they're flush. It might just be a visual thing, but it looks like there's a small gap.I will try reseating the 24pin later and see if it changes.
So they're mounted horizontally and not vertically?PWRSW is the first label and under the label there are two lines, the lines lead to the pin-1 and pin-2 (PWRBTN & GND). The lines stop at the pin. Is that clearer?
I can't answer that because the manual is the opposite orientation to your picture (i.e. in your picture they're vertical, in the manual they're horizontal), try to follow the lines from the label like I described.So they're mounted horizontally and not vertically?
frm diagram it's only the left 4 pins you need. just looking at some old photo's but my 5000x case, using a b550e-e board and my b650e-e board is using lian li case where are the plugs are integrated into 1 plug..but from look same layout of actual set is the same, but on b650e-e they all start on leftPage 32, it's not really clear to me... I will try reseating the 24pin later and see if it changes. I seriously thought assembling a PC got easier, this is pretty much as it was 20 years ago minus a few pins...
