Is this worth £38? So tempted to buy
Did you play the first one?
It's more of the same, so if you liked that, pretty sure you will like this.
Great pair of games IMO, and well worth the buy.
Yeah I did in general, dragged a bit when doing the DLC. I was just wondering if all the bugs etc were fixed tooDid you play the first one?
Came here to post the exact same thingDiving mask acquired![]()
Do you have to have played the first one to enjoy the second? Looking at picking it up, but my friend was saying something about playing the first one before i do.Did you play the first one?
I would play the first as its quite cheap now.
Man setting up the game took a bit of time. Still not sure about the HDR settings but it seems okay. I turned off all the DLSS as it produced minor stutter when rotating the camera at high speed, running with just DLAA.
Can't decide if I should play pad or kb/m, I'm so used to aiming with the latter and I'm really bad at aiming with the pad, it just doesn't snap to the point I want like a mouse would which kind of matters when going for weak points.
edit: I had to manually add it to the app list so I could set game optimisation to high performance. (Crashed during prologue first time I ran it without, not sure if it made a difference)
Game does look awesome.
