@squerble the UDR may be a better entry level device for your needs.
The built in AP is 4x4 instead of 2x2 and it has an integrated POE switch. Then add a U6 lite as a second AP somewhere.
You can also run protect on it so if you really want to spend more money, you can run the Ubiquiti door bell off it and ditch Ring. I wouldn’t recommend handing more cameras than that off it though as it’s Micro SD recording only.
