The AMD Driver Thread
Anyone by chance read anything if AMD are going to work on getting Fluid Motion Frames working under Vulkan ?
Should be working already, tried RD2 a while back and it was enabled.
The keyboard shortcuts to enable/disable don't always work as playing AFOP the shortcuts stopped working near the end of my playthrough.
Create and save a game profile and enable it there as it bypasses the CP reboot to default(AFMF off) problem.
Or, there's a link only YT vid on how to manually add Vulkan support here:
Yep, Also other games using Vulkan like Red Dead Redemption 2. Would be nice to use it.
ARSeD Discord, were looking for Kopion to kidnap and take in to a space station for the lols...
like this unhappy chap
Highlights​
  • New Game Support​
    • The First Descendant
    • Once Human
  • Expanded HYPR-Tune Support​
    • HYPR-TUNE Profiles
      • Like a Dragon 8: Infinite Wealth
      • Overwatch® 2
      • The First Descendent
      • F1® 24
      • Outpost: Infinity Siege
    • Click HERE for more information regarding HYPR-RX.
      • Enable HYPR-RX and get an instant boost in performance of up to 149% on the Radeon™ RX 7800XT GPU across games like Baldur's Gate 3, F1 23, Resident Evil 4 and more! RS-642
      • Join the conversation by sharing how well HYPR-RX with AFMF is working on your system. This information across thousands of games helps us make further improvements.
  • Expanded Operating System Support​
    • Support for Windows 11, version 24H2.
  • AMD Radeon™ Anti-Lag 2 Support for Counter-Strike 2​
    • Takes responsive gaming to the next level by introducing an in-game option to optimally pace frames, further reducing input lag on AMD RDNA™architecture-based discrete and integrated graphics products.
      • Get a decrease in latency in Counter-Strike 2 of up to 40% with AMD Radeon™ Anti-Lag 2 at 4K on the AMD Radeon™ RX 7900 GRE graphics card. RS-647
      • Get a decrease in latency in Counter-Strike 2 of up to 27% with AMD Radeon™ Anti-Lag 2 at 1080p on the AMD Ryzen™ 7 8700G processor with AMD Radeon™ 780M graphics. RS-651
    • Learn more about AMD Anti-Lag 2 HERE.
  • AI on Radeon​
    • Performance improvements and memory footprint reduction for Large Language Models (LLMs) thanks to 4-bit quantization acceleration support for all RDNA™ series discrete graphics products and RDNA™ 3 series integrated graphics products running ONNXRuntime with DirectML.
  • AI Development on Radeon​
    • Technology Preview for Windows Subsystem for Linux (WSL 2) enabling PyTorch users with supported hardware to develop with AMD ROCm™ software on a Windows system, eliminating the need for dual boot set ups.
  • Expanded Agility SDK Support​
    Introducing support for Agility SDK 1.613 and Microsoft's Agility SDK 1.614.0 functionality:
    • Microsoft DirectX 12 Work Graphs 1.0 API
      • D3D12 Work Graphs support for AMD Radeon™ RX 7000 Series graphics cards, learn more HERE
    • GPU Upload Heaps
      • See the DirectX Blog HERE, or our GPUOpen Blog post on GPU Upload Heaps HERE.
    • Shader Model 6.8 – Including Wave Size Range and Expanded Comparison Sampling
    • R9B9G9E5 Support for Render Targets and UAV
  • Fixed Issues and Improvements​
    • Fallout 3 and Fallout: New Vegas may fail to launch.
    • Improvement to intermittent driver timeout or application crash experienced while playing HELLDIVERS™ 2 on AMD Radeon™ RX 7900 series GPUs.
    • AMD Software: Adrenalin Edition Performance Metrics may intermittently fail to update while playing HELLDIVERS™ 2.
    • Intermittent system freeze or low FPS on hybrid graphics notebooks pairing certain FreeSync enabled displays.
What to Know​
    • Anti-Lag 2 will be enabled by default in the Counter-Strike 2 “ADVANCED VIDEO” settings menu.
    • Anti-Lag 2 unlocks improved responsiveness by adding in-game pacing of the CPU with the GPU, particularly in GPU-intensive scenarios.
      • For more information on how to use Anti-Lag 2 and measure latency click HERE.
      • Join the conversation by sharing how responsive is improved with Anti-Lag 2 on your system.
Known Issues​
  • Virtual Super Resolution or Display Color Enhancements may be set to disabled after driver upgrade. [Resolution targeted for 24.7.1]
  • Corruption may be observed while playing Dying Light 2 Stay Human: Reloaded Edition with Radeon™ Boost enabled. Users experiencing this issue are recommended to disable Radeon™ Boost as a temporary workaround.
  • Intermittent in-game corruption may be observed while playing Ghost of Tsushima DIRECTOR'S CUT with AMD Software: Adrenalin Edition™ Record & Streaming and HDR enabled.
  • Intermittent black corruption may be observed on scaled 3d models while using Origin or OriginPro application. [Resolution targeted for 24.7.1]
  • Audio and video may intermittently become out of sync while recording using the AV1 codec in AMD Software: Adrenalin Edition. [Resolution targeted for Q3]
Package Contents​
Highlights​
  • New Game Support​
    • Once Human
      • Overwatch® 2
      • F1® 24
  • AI on Radeon​
    • GPU Upload Heaps
What to Know​
Known Issues​
new driver performs worse for me in elden ring by about 40% on a 7800xt with same settings in the game and the gpu driver. I've also somehow lost the 75hz refresh rate i had before the update and can now only set to 60hz. good to see it was tested before release :p
edit: reverted to previous build and everything is back to normal.
Remember to clear the shader cache. I installed the 24.6.1 over my old driver(24.4.1) and spite selecting factory reset it didn't clear the shader cache causing horrible performance. If you don't know where it is then go to Gaming -> Graphics -> bottom of the global list -> Reset Shader Cache.
didn't do this, so likely is the problem in regards to performance, i ran a ddu first and a factory reset. il try it later on and see if it helps cheers.
We've not observed anything like this internally with 24.10 based drivers like 24.6.1 Are you using a mod to uncap the in-game frame rate?
There was a bug in 23.40 based drivers which exposed display modes where it shouldn't have, though I can't recall if this was specific to VSR modes (I'm pretty sure it was specific to VSR 3 on RDNA3).
As for shader caches, you generally shouldn't have to manually remove these; older caches are automatically invalidated as needed.
no only thing i used was chill set to 71-74 (which i always do no matter the driver version), but then i noticed the refresh rate issue after setting it, tried quite a few different things to get the refresh rate back, tried to also set a custom resolution which didn't help. then i noticed the the performance issues - it was like i was capped at 40fps in game but no caps set and i lost a whole bunch of resolution options, so i decided to roll back. il give the upgrade another go if i get chance this evening, maybe something went wrong during the install causing an issue along the way.
