Cousin didn't have a fun time, double broken collar bone, nine broken ribs and a punctured lung
Thankfully he's ok and being well looked after![]()
Glad he is ok, that must have been one hell of a smash.
Yeah, someone went down in front of him and he took avoiding action. Never been out with him, but he was looking for a four hour time so would have been going some I think, certainly way quicker than me.Glad he is ok, that must have been one hell of a smash.
Have been toying with getting the Assioma duo shi power meter pedals for ages now but could never quite justify the cost along with worrying about the extra q factor and the fact I have some nice dura ace pedals already. Found some guy selling a 4iiii left hand PM crank on facebook for £230 and we are swapping crank arms. He gets my non PM one and I get the PM one.
Looking forward to no longer getting home after a ride and arguing with Strava about my average power!
Nice deal.
I've also got the Look compatible Assioma Duos and I can't say I've ever noticed differences going between them, Look Keo Classics (turbo bike) and 520 SPDs on my winter bike. I had Ultegra SPD-SLs on my best bike before the Duos. I might just be weird and pedal like a baboon though!![]()
thinking more of a future problem. Do you know if the cleats which the assiomas use are compatible with regular look pedals? When I (eventually) get a new bike I'd like to put some regular Look pedals on my old bike so that I can use the same shoes/cleats
I'd presume they are. I sort of remember GP-Lama doing a test
and swearing occurred but I stayed upright. I had big trouble unclipping both feet all day which become quite frustrating.Just keep pulling until the two parts separate. Voila!
Can the Module on My Garmin HRM Be Removed From the Strap?
The HRM-Dual™ monitor is the only current Garmin heart rate monitor strap that has a removable monitor. The following advanced monitors have the module integrated into the strap itself for ideal performance
The HRMs should be washed by hand, after seven uses. The HRM-Pro, HRM-Pro Plus, and HRM-Tri should be washed after each swimming pool use. For full care instructions, see the Care Guide.
- HRM-Fit™ monitor
- HRM-Pro monitor
- HRM-Pro Plus monitor
- HRM-Run monitor
- HRM-Swim monitor
- HRM-Tri monitor
Going to change the battery and see if it helps, if not then given how often it's failed, i'm not sure i want to trust Garmin again so might just go Wahoo/Magene.
) in about 2 years. Looks borderline brand new still as well. When you connect it to your head unit it should tell you what the battery status is. Can't hurt to try and replace the battery at any rate.Had zero issues with my HRM-Dual (the one with a removable strap) in about 2 years. Looks borderline brand new still as well. When you connect it to your head unit it should tell you what the battery status is. Can't hurt to try and replace the battery at any rate.
Hey i wouldn't say i had an issue with this one since Feb 2022 so you might be due![]()
Yep, I'll take a painful shoulder over broken bones/head. Sudden failure of the chain though, I had given it all a check over before Ride London on Sunday, chain was well within tolerance. Maybe I'm pushing too many WattsWow. Glad to hear you're alright (relatively speaking)
Could be an opportunity to upgrade my drivetrain though...before @Junglist gets his Di2
if you are awaiting for @Junglist , you have plenty of time, di2 will be 4 gen old by that time...Yep, I'll take a painful shoulder over broken bones/head. Sudden failure of the chain though, I had given it all a check over before Ride London on Sunday, chain was well within tolerance. Maybe I'm pushing too many WattsCould be an opportunity to upgrade my drivetrain though...before @Junglist gets his Di2
I keep asking how the house sale is going they must be on to me.... I suppose I'm glad you're alright @-westy-
My genuine fear now is when I do buy it, it'll be replaced the next weekI keep asking how the house sale is going they must be on to me
Tubeless sealant: What's everyones go-to? I've been using Stans but wondering if there is something better/more cost effective.
