- 26 Dec 2003
- Cambs UK
Would prefer the big tasty on the menu permanently tbh
As with most McDonalds, it needs more sauce.Tried the new hat trick burger today, actually wasn't too bad.
When did they do a hot dog? I cant recall ever seeing oneAs with most McDonalds, it needs more sauce.
they also need to bring back the hot dog.
They’d have to make it with beef. They can’t cook pork at the same time they are cooking beef, that’s why they’ve never brought the McRib backAs with most McDonalds, it needs more sauce.
So how do McDs prevent cross contamination of breakfast (meat all pork) to rest of the day? They could have just one section in the kitchens dedicated to pork all dayThey’d have to make it with beef. They can’t cook pork at the same time they are cooking beef, that’s why they’ve never brought the McRib back
Bring back the Great Tastes of America/The World. Obviously not genuine but had more originality than slapped an extra, sometimes unnecessary burger
I'd love to know the actual cost to the franchisee for the food.Nothing really, pork sausage is booked on the exact same grill as the beef. At the end of the day, it’s all throughly cooked so I’m not sure what risk of cross contamination you are thinking of. If you go into a proper restaurant, they’d be cooking chicken, beef and pork on the same equipment all day.
At the end of breakfast service, the grill will get a good scrape (the pork leaves a lot of carbon residue and needs a good scraping after every batch to ensure you don’t get carbon build up on the surface of the grill), it gets a quick wipe down with a clean cloth to remove any pork fat/grease. The utensils (tongs and spatula) are swapped for a clean set and you start banging out the beef.
During the swap over time between breakfast and main menu, you’ve literally got 2-3 minutes to clean down, swap the meat in the freezer next to the grill and start cooking again. At the end of the day customers don’t tolerate a wait, if you stop breakfast, they expect a cheese burger within minutes.
The sausage is held in hot cabinets and had a decent hot shelf life but you tend to cook small batches right up until the end to reduce/eliminate waste and avoid the risk of running out. As much as these places make a ton of money, it’s only on the volume. The margins are razer thin so food waste was a huge focus.
Back when I worked there food was the biggest cost with labour a close second, the two things were tightly controlled.
2002.When did they do a hot dog? I cant recall ever seeing one
It’s probably more than you’d think, the ingredients are extremely consistent (the tolerance on a meat patty is near zero or it won’t cook properly on the equipment) and pretty decent quality and that costs money.I'd love to know the actual cost to the franchisee for the food.
Because they don’t have enough grill space in uk restaurants for separate dedicated grills and they can’t cook different meats together on the same grill due to potential food safety problems. So they can only do pork at breakfast and beef the rest of the day.What? Why?
Not necessarily true.At the end of breakfast service, the grill will get a good scrape (the pork leaves a lot of carbon residue and needs a good scraping after every batch to ensure you don’t get carbon build up on the surface of the grill), it gets a quick wipe down with a clean cloth to remove any pork fat/grease.
The packaging or production of the food costs more than the ingredient.I'd love to know the actual cost to the franchisee for the food.
They don’t cook different meats together. It’s not a food safety issue, it is that they fundamentally wouldn’t work.Because they don’t have enough grill space in uk restaurants for separate dedicated grills and they can’t cook different meats together on the same grill due to potential food safety problems. So they can only do pork at breakfast and beef the rest of the day.
This is the same reason as to why Fries, nuggets, fillet o fish and apple pies are not all cooked in the same oil.The thing about mixing products is more to respect belief structures (be that religious or vegetarian/vegan), not food safety. Likewise you don’t want your beef tasting like pork because there was a bit of pork grease left on the grill.
Plus lets not forget, that the products are prepared on the same production line as meat products, so even with all that care, separate gloves and utensils they still used to carry a disclaimer saying it can't be truly ensured vegetarian due to potential cross contamination. At least when i was last behind that line myself anyway.Sort of but also sort of not really.
Nuggets, fillet, veggie and pies used to be cooked in the same set of friers. The oil was separated but it’s ultimately filtered through the same mechanism and there is a certain amount of mixing of the oil when this happens so there are traces of meat in the pie, fish and veggie friers.
They redesigned the veggie products so they could be cooked in the frier used only for chips which operates at a lower temperature. When they did this, the product was then approved by the vegan/vegetarian society. The pies are not as they are cooked in the same set of friers as the chicken and fish.
Most vegetarians are generally not concerned though and accept their are limitations to how far one can go in a kitchen that produces meat products. Occasionally mistakes also happen and things get into the wrong oil.
