As a man you need plenty of supervisionCut the bamboo back in the week, and dug it out today. Wife, child, and dog all just stood there helping.
Hopefully I got all the roots out or whatever they're called.
Felt like I was at work, PMs asking me every 6 minutes how I’m getting on.As a man you need plenty of supervision![]()
Looks like there wasn't any scope creep at least.Felt like I was at work, PMs asking me every 6 minutes how I’m getting on.
To be fair the wife did help a little. The tantrum machine less so!
Can you please take some time off you're making me tired just looking at your picturesSo....started early, and sanded all the joint and tape down. It's about 98% with some obvious sketchy bits where there is the compound joint in the ceiling but it'll do me. My main aim was to make it functionally better rather than Instagram perfect - so it's been rewired, insulated against the cold walls, cat6 etc...
Two coats on the ceiling - trade diamond mat is legendary stuff. One coat on the walls so far as I am chancing a few slightly iffy backings (old paint that withstood 60grit but once wet may flake....). I'll give it till midweek then give it a final coat.
I need to have a think about the top cupboard doors, maybe just some fresh hinges and a paint. The wardrobe door I've been told will be a curtain, so I'll try and box out the pipework at some point...
Not bad given it was this (during the heating replacement about 18months ago) :
Edit: I also finished the soffits and fascias on the summer house so I'm ready to glue the rubber now. And mowed the lawn.
It's an overflow isn't it? Old toilets used to have a separate pipe for overflow. Newer ones just overflow into the bowl.Hi all, not worth it's own thread but I'm replacing my ensuite bathroom soon (it doesn't look like its been touched since the 70s); does anyone know please what this white vertical pipe is called / is for?
I'm assuming it's some kind of air admittance pipe, but didn't know they ever did them exposed like this? Thanks.
Could be for the toilet overflow or an old waste pipe.Hi all, not worth it's own thread but I'm replacing my ensuite bathroom soon (it doesn't look like its been touched since the 70s); does anyone know please what this white vertical pipe is called / is for?
Ha, well I never. Thanks all!It's an overflow isn't it? Old toilets used to have a separate pipe for overflow. Newer ones just overflow into the bowl.
You found your dog then?Managed to borrow dad's petrol brush-cutter & mower, then roped the brother-in-law for a day of graft (well paid, of course).
Before:
After:
I'm not fussed that the lawn is in shocking condition - so long as the Fluffy-Nutter can do her business without getting lost and the kids can kick a ball, I'm happy.
Plans are to remove the concrete monstrosity dissecting the garden, build a 3m deep patio level with the back door (swapping the PVC window panel out for french doors), then create a ramp down the brick wall side of the garden to a paved area by the back gate.
I'll build a "Catio" enclosure off the left hand GF window (my study/den) so the moggies have a safe & secure outdoor area.
The garden's too small to do much else with - I'll put planters/vertical garden boxes along the brick walls (bricklayer nephew will replace the remaining fence with walls to match) for greenery, but ease of maintenance and usable space is the priority.
Looks like the dogs had a haircut as well. Obviously got a little close to the strimmerYou found your dog then?
^ post from FebThe man job I'm starting soon is to find the bore scope camera that I 'put somewhere safe'...
Yes you did need it, because if you needed to look behind the cupboard^ post from Feb
FIANLY FOUND THIS **** OF A THING
Now that I don't need it.
It had fallen behind a cupboard!!!!
As long as you didn't leave it under a floor board. Maybe they should build them with a tracker?^ post from Feb
I'd need a lot, the amount of times I can't find tools hiding in plain sightAs long as you didn't leave it under a floor board. Maybe they should build them with a tracker?
