22 is less than my 440i gets. I'd be annoyedimagine it costs a fair chunk, not a fan of the massive screen as it would be a bit off putting.
I'm driving a 3 Series GT and according to the iDrive i average 22mpg, anyone know if that is about right? Its a 328i. I don't mind terribly as i only do 5-6k miles a year just seems a bit low.
I'm toying between replacing it with something electric through work, keeping it or changing to a X3. There's an X3 M40i near me but not sure the power is needed and the running costs i suspect will be a fair bit higher. There's also a X3 30d M Sport with 4 additional packs added to it which is a bit cheaper but a bit slower.
I've only ever bought a car because my other ones have died rather through choice.
according to auto trader urban should be 34mpg, wonder if that's having it in eco mode or something. i'd imagine your 440i is much more fun to drive than mine too.22 is less than my 440i gets. I'd be annoyed
B58? If so it’s a bit of a freak engine and often outperforms 2 litre petrols not only performance but also economy.22 is less than my 440i gets. I'd be annoyed
i "upgraded" from a '63 N20 428i to a '18 B58 440i, so basically the same engines as to what you have and what you're looking to getThere's an X3 M40i near me but not sure the power is needed and the running costs i suspect will be a fair bit higher.
So the M2 is currently averaging low 20s, as I've been enjoying it rather a lot
However, even motorway cruising is compromised due to the lack of 7th gear.
I assume being a BMW it won't blow up if I stick 95 in it for long distance cruising? It's the N55 and not the S55 engine, if that makes any difference. Ta.
Yes, but just wanted to find out what it will actually do. ThxDoesn’t it say on the fuel flap? Mine says V Power recommended but will take 95. It will just back off the timing and give you less power but as you are cruising it doesn’t matter
Out of interest, is it the same for S-coded engines?
It'll be fine, I normally average about half / halfSo the M2 is currently averaging low 20s, as I've been enjoying it rather a lot
I just use whichever fuel grade the manufacturer recommends - which they presumably do so for a reason. Not sure why you'd want to do otherwise?
