But did you 100% the entire map?? I've driven every road and found stuff
Inc buried bodies under water and shard with extended backstories.
Great mod.
CoolCam - Immersive Vehicle Cameras
The default camera has bothered me since launch. The goal here is to provide immersive angles without sacrificing road visibility. Changes have been made to camera position, boom-arm elasticity, FOV,www.nexusmods.com
Great mod.
Anyone tried the spatial audio pack yet? Was supposedly released 3 days ago...
I'm using a 4070 Ti Super using the settings that the game recommended, but I'm getting the odd stutter as I'm playing which is quite jarring.
Are there any well known or obvious things that might cause this? I'm generally getting 100+ FPS, so I don't really understand what the stuttering is as the FPS isn't dropping. Thanks
Thanks for the suggestion, but it's more frequent than that. I've run the benchmark a few times and it seemed a bit better with DLSS off, but obviously the frame rate is much lower then.The games autosave function causes a stutter every time it saves - you sure its not that? They are fairly infrequent if you stay in one area for a while but if you travel quickly between areas it will be more often
tried this mod lastnight, causes all sorts of the traffic issues and pileups, it was funny to watch though!![]()
This mod looks cool actually, lots of dynamic NPC reactions which is nice to see now.
I haven't had an Nvidia card for ages so wasn't sure if I was missing something obvious, or if it was a common problem. I might try and record it to show what I mean.
Otherwise I'm quite enjoying the game, it's so much better on PC compared to console and I think one of the reasons why is because some of the combat is so chaotic. It was just too difficult to keep up with and feel like I was.in control with a controller. The game looks amazing as well.
Edit: just seen a video on YouTube where MSI Afterburner/Riva Tuner are recommended to cap frame rates, rather than in game frame rate capping, as this produces more consistent frame times. Or something like that. Anyway, I'll try it later and see if it helps.
