That is the hot water tank effectively. You can even use it with a gas boiler to improve efficiency, though I'm not sure it would be that financially worthwhile.So with that. You don't need a hot water tank? People with combi boilers can just do a swap?
It's more like an energy buffer to create hot water on demand. Once the temp drops inside, the heat pump kicks in and keeps the water heated perpetually.
