- 23 Mar 2011
Clutch click is likely that the piston to pedal linkage needs adjusting. Mine was way out when I got it. You need to be either a contortionist or remove the drivers seat to get to it. There is a lock nut and then you can turn the linkage to take up the play.
With regard to the plates either side of the instruments, mine were scratched a little too. I never found anything that matched the radio door but in the end I bought some carbon fibre overlays that I stuck on. They look OK.
The red interior is so much nicer than my boring black I have. Really lifts it and makes it feel less claustrophobic.
Thanks for the tip, will look into it. Seems to be doing it more now.
Yours is looking great ^ mines out in the rain today
Spoke to one of our customers over the road, they know their stuff and are going to give the car a once over and do a service for me. I've asked to do all fluids etc, any other key things to get them to check?
They are currently building 3 race engines for a Honda of some sort
