- 18 Oct 2002
- England
What about when you start to get to 8000mhz and above, is there a tipping point where running 2-1 mode becomes better than 1-1.So far most tests I've seen of memory over 7000MT with 2:1 mode shown that in most cases timings matter more than speed. It's usually better to run 6400MT with tighter timings than the faster modules. But it depends on use case. There's a reason AMD said new CPUs have sweet spot of 6400MT 1:1.
They both have same memory controller apparently (current and 9k series), so should behave in almost the same (if not identical) way with memory
It reminds to be seen, so far I've not seen tests that would show definite advantage of faster memory Vs 1:1 one with tighter timings.What about when you start to get to 8000mhz and above, is there a tipping point where running 2-1 mode becomes better than 1-1.
It doesn't match here;+10%S
- 2% M
That's...not great is it.
Surely, suuuurely that's not right :/
Yes, apparently review samples have shipped already. Should see reviews sometimes in next 3 weeks.I guess that's better, but as good as hoped by most people?
We'll soon(ish) find out![]()
The 7x chips run cool when the power is dropped, its the boost that jacks up the heat.Hopefully that turns out to be genuine. It's cool running to although it doesn't say what cooler was used. Looking good.
Ryzen 9 9950X processor - single-core is +14% higher than Ryzen 9 7950X, multi-core is +7%
New benchmark scores for the 16-core AMD Ryzen 9 9950X processor were revealed, showcasing its performance enhancements over previous models. The 16-core processor, identified as 100-000001277, utilizes two Zen 5 CCDs and one IOD, supporting 16 cores and 32 threads.www.guru3d.com
They show the 7950X MT score at 19227.
Depends how good the benchmark is.But the 9950X only scored 20550, thats like 1 or 2% faster in synthetics, you're not going to notice any real world performance difference at all.
AMD have said that Zen5 will not be faster than Zen4x3d in most games, on average. We'll see big gains in productivity and general compute, but will have to wait for Zen5X3D for a big gaming performance increase.Depends how good the benchmark is.
I think there'll be a decent uplift in games given the decent single threaded performance.
