Annoyingly the one TV show I'm watching on Prime and it's sodding not 16:9 but also not ultrawide either so I either scale it up or down between either screen lol.
I thought exactly the same haha, looks good tbh I really like the curveAh, the boys. We watch that too
It's weird, I actually thought that was a pic of your ultrawide there, looks pretty wide to me.
Oh it'll turn up the moment you leave, always the way lolMine's scheduled to be delivered between 08h30-10h15. I hope it arrives after 09h00 because I have to do the school run!
My only counter to this is that smoothness at higher refresh rates also plays a considerable factor.Higher resolution is better, always has been.
I'd rather play at 1080p 240hz than 1440p 144hz - although the benefit now is that we're getting the best of both worlds with 4k 240hz. Right now I'm enjoying 1440p360hz but I am definitely tempted, when 27" OLED 4k panels release, to change to this.
My ideal would be QD-OLED 27" 4k@240hz - but with that 'dual' mode that LG have that could do 1080p@480hz. Throw in USB-C power delivery and that's honestly my dream monitor right there.
Totally agree higher res has always looked superior to upscaling on a lower res screen. Even when comparing a higher dpi 1440p to a low dpi 4k, the 4k is still more detailed. It surprises me that mrk is only just getting onto this![]()
The ETA changed to 07h10-09h10 so I sprinted home from the school run, and now it's changed to 14h10-16h10!Nexus will see the light soon also. Though if he can't sell his 34" I can see him saying ultrawide yada yada to justify his choice of sending the 4K Alienware back![]()
What I mean is the screen's native res being used is the key factor here, using DLDSR on the 34" is higher than 4K res, 5160x2160, yet becaus ethe screen's native isn't that res, and the PPI is smaller, we don't see the true benefit of that ~4K res being used whereas we do on a 4K native res display at 32" thanks to the increased PPI.Higher resolution is better, always has been. You don't need high res textures like a lot of people claim either. It does help make it better though of course.
There is a reason I was on stuck on 4K from 2014 until I got my QD-OLED. Every time I went to try 1440p or 1080p it felt like a big downgrade in image quality.
And this is why I have been wanting the 32" 4K Alienware since release
Looking forward on his take over the weekend also![]()
Yes DLSS Perf on a 4K display is cleaner/crisper than DLDSR 5160x2160 on a 3440x1440 panel, but that's due to the PPI being higher on the 4K panel. I was using DLDSR with both Quality and Performance and the same results apply, the lower PI on the 34" ultrawide simply means the clarity, whilst good, can never be as good as higher PPI on the native 4K 32" also using DLSS Perf or anything else.How would you say 4k with dlss perf. looks compared to dldsr 3440x1440. I know you said further back about still being better clarity etc. but wasn't sure if you were factoring when using dlss performance mode in as well.
The curve is basically not apparent but then again the 34" ultrawide at 1800R wasn't apparent either, both 1700 and 1800 are subtle curves at this size and are perfectly fine for any use I've found.How do you find the curve on the smaller screen @mrk?
