- 4 Oct 2019
- Queens Park - London
You’re going to love how much faster your pc will be.Purchases have been made. I explained my predicament to my wife and we discussed it.
"We" are getting the 5700x3d, and 2x 16gb RAM. I have also ordered a 2tb M.2 SSD. I had a long hard think and this should to me well for a while, with a GPU upgrade at some point down the line.
The wife and daughter will cover the extra cost as my Bday present (which I reluctantly agreed to).
Everything should be here tomorrow.
Is there anything specific I need to do when downloading the BIOS update to a usb drive?
Basically, if your getting a gaming system these days, you get the X3D CPUs as they are some of the fastest.
Use your stock cooler for now in regards to what cooler to use - AMD CPUs don’t run as hot as Intel CPUs and it should work.
If it doesn’t, get a second hand tower cooler.
