Corsa or Corsa Pros usually, good tyre if they're £20 a pop. but then they will be too narrow for you ladsIf you sit a normal width saddle (143mm) then I can do you a deal on a genuine Power... I've sold 1 new with came with the original SL7, but I'll likely have a new one with the new SL7. I've got a grey one with a yellow S BNIB (although a couple of years old) and at least 2 others used (1 is in use)... Switching to the 155mm width was/is an ongoing project!
Weird, yeah the Mantel website shows things: https://www.mantel.com/pl/continental-grand-prix-5000-s-tr-road-bike-tyre but then when you change your country to UK at the top... Takes you to https://www.mantel.com/uk and says "We're leaving the UK"...?!
Found the Rubino's IV I got for winter pretty uninspiring to ride... But also pretty solid for the money. They're on a buckled and badly dented Fulcrum rim from a pothole. Not tried the softer/premium ones... Found them pretty horrible to mount so not sure what to do with them... They wouldn't go on my usual winter wheel (Zipp 30 Course) but have found the rims tight fitting on other tyres, actually bent a rim mounting them after several days (RIP a dozen tyre levers). Hard but not impossible to mount on the Fulcrum Racing 7 wheels, so they finally got some use after buying them several years previously... Then a few months later badly dinked/dented them on a pot hole. Grr!
