Ended up with Bison vertical fake oak "in vogue" stuff for the front, and then roofing sheets back and sides. Should come on Friday.... need to work out how to trim it down as they only had 3m height in stock!What cladding you going for?
Looks nice, I will definitely be going for some composite material like this over real wood when I start mine. I do wonder how many people end up disappointed later on when installing cedar for cladding.Ended up with Bison vertical fake oak "in vogue" stuff for the front, and then roofing sheets back and sides. Should come on Friday.... need to work out how to trim it down as they only had 3m height in stock!
Yeah deffo. Just hope I have enough - I did 16 sheets and that is JUST within the amount I need...Looks nice, I will definitely be going for some composite material like this over real wood when I start mine. I do wonder how many people end up disappointed later on when installing cedar for cladding.
Ah yes, sounds much simpler and less to go wrongThinking about getting and electric stop penis fitted
Turns out it's not electric, it's lever operatedAh yes, sounds much simpler and less to go wrong![]()
Praise the gods for the internet'sThere is one yeah but in typical fashion it's a weird one.
It's a 6-sided nut, can't seem to find a tool for itwill ask around.
You can just say stopcock.Praise the gods for the internet's
Internets said to look at neighbours stop penises for the tool, and hey presto, I found one, long and thin
Ah I tried stop **** but it didn't work... stopcock!You can just say stopcock.
That's numberwang!This is going to degenerate into a game of ballbags isn't it
Eleventy twelve!That's numberwang!
game of ballbags
Forgot I had doubled up the roof joists....FFS.
(just going to notch it with the multitool).
Just realised as well, my cladding will probably come out a decent amount. Oops. All in all, a fail of a day![]()
Recess for light hit a joistWhat am I supposed to be looking at, you ran out? What are you notching?
I've got the same type of blocblinds in my Home cinema room, absolutely stellar.. almost 100% light blockage, just the teeniest speckle of light creeps under the bottom bristles on a very bright summers day with the sun fully on the window.. also helps cool the room in summer!Hmm thanks. Feels a bit hit and miss. Makes me wonder if I should just go to MDF!
Had a simple job today...to fit the blackout blind. I was meant to fit out the remaining shelves but got distracted playing lego with my 4y/o. Turns out the blind came at the lowest end of their tolerance, and I had given my smallest measurement, so it was very unforgiving. I had to shim out the right hand wall which blew some plaster; so it has created 3 or 4 other steps for me...annoying. But these blinds do work extremely well, and feel very solid.
Screwed and pinned the top back as it was under compression even after taking off a saws width on the mitre.
It works great tho... just need to finish off the wardrobe and a few other minor snags and it is done forever... thank god.
Aye... This is our third one. The inside recess has been least forgiving, altho I hadn't realised quite how out the wall was!I've got the same type of blocblinds in my Home cinema room, absolutely stellar.. almost 100% light blockage, just the teeniest speckle of light creeps under the bottom bristles on a very bright summers day with the sun fully on the window.. also helps cool the room in summer!
Most people hate the bulkiness of the side channels, but if you want no light, I think it's the best solution by far, absolutely zero light leak from the sides which is where most fall down.
