- 9 May 2022
- London
The photogrammetry around Cork is now absurdly good
You can make a copy of the main file, can't remember which exactly, but you can Google it.Just bought this and downloading it now. My partner's internet is very slow and expect a couple of days before I can play.![]()
I used openxr (with reverb) to mess around with stuff, but I still get poor looking graphics.VR is very nice indeed. Is there a way to tweak the graphics so it looks less shimmery and blocky in places?
Edit: Using a Quest 2
Fenix have released their A319/A321 - bargain at £40 for both.
The flight deck layouts are largely the same, but they each have their own handling nuances. The A319 is a pocket rocket which will get you in and out of smaller fields. The A321* has the range, but you can very easily spank its backside on the tarmac.Is there any major difference in flying them to the a320 ?
Looking for some help with the default Cessna Caravan autopilot in MSFS 2020.
I'm currently flying the default Cessna Caravan and having issues with autopilot during landings—it won't capture the glideslope.
Here’s what I’m doing:
After takeoff, I press the CDI button to select GPS, set my altitude, and enable autopilot. I engage NAV and ALT Hold. Then I use Vertical Speed mode to manage my climb.
As I approach the airport, I tune into the ILS frequency and begin my descent using ALT Hold and Vertical Speed mode.
Once closer to the ILS, I press the CDI again to switch from GPS to ILS, ensuring NAV mode is still active. The autopilot captures the localizer fine, and I can see the glideslope indicator on my instruments.
When I press the Approach (APP) mode to capture the glideslope, the plane completely ignores it, with ALT Hold still engaged. Even when I turn off ALT Hold and leave APP on, it doesn’t capture the glideslope. In some cases, APP mode turns itself off, and ALT Hold re-engages automatically.
What am I missing here?
It’s not a huge issue, but sometimes I want to let the plane handle the landing for me.
