- 29 Sep 2010
That's absolutely fine by me, they're just sat thereMore than happy to take it on.. I am pretty busy right now so it might take me a while![]()
That's absolutely fine by me, they're just sat therethank you, I'll send you a PM
My wife hates the amount of electronics I buy...she would go mental if I were like youI actually have a spiderman ps5 pad on the way as well as another 5 xbox consoles an evercade handheld and some other bits that should be here tomorrow.
My wife hates the amount of electronics I buy...she would go mental if I were like you![]()
What an interesting thread. I’m off work with back ache and this really cheered me up.
Possibly you could use the same technique used for old computers:Not sure if you've done any restorations but I've got a white 4g router that turned yellow. Can I restore the original colour back?
Transparent purple is defintely the winning colour. Looking forward to seeing your Gamecube. I keep being tempted by the Gamecube but I've got a Wii that plays GC games and a SteamDeck too so I don't need one. Do I?
Transparent purple is defintely the winning colour. Looking forward to seeing your Gamecube. I keep being tempted by the Gamecube but I've got a Wii that plays GC games and a SteamDeck too so I don't need one. Do I?![]()
I have a Gamecube with a Xeno XC modchip, and use an SD card via the port underneath via a little adaptor.
I use the drive to boot an out of date Swiss, which then boots a newer version from the SD card.
Does the Picoboot install achieve the same thing just without the need for the optical drive at all?
