Re-Installing Loft Flooring and Fixing the Errors of the Past
15 Sep 2008
I previously posted some images of my loft flooring project and the issues I found in the man jobs thread and thought I’d make this thread to keep it all together. So here we are!
The loft always had issues.
  1. Shortly after moving in a few years ago the ceiling below the loft started to show cracks at the taped joints of the plasterboard. There were tell-tale signs of a previous repair so I knew it would just happen again if I repaired them – the cause had to be found and fixed first.
  2. Similar to above, there were some cracks between the coving and ceiling in some rooms that would open in the winter and close in the summer. I filled these cracks previously with caulk but they just came back. This led me to think it may be caused by truss uplift.
  3. It never felt particularly dry in the loft either and this was made worse when the soffits were replaced as this sealed it up and insulation placed over the soffit restricted any airflow in and out of the loft. Any moisture was trapped.
  4. The flooring was uneven and seemed “soft” between the joists and creaked when I walked over it, suggesting the floorboards were compromised and had some movement in general.
  5. I discovered that whoever installed the extractor fan for the ensuite thought that it was acceptable to just vent in to the insulation! Really?!
  6. To fix the ensuite extractor fan issue I installed a new fan and ducting to the outside but the fan always leaked condensate despite the ducting being insulated. I need a permanent solution.
To mitigate those issue this is what I’m planning:
Issues 1 & 2 – When the previous owners floored the loft they only floored one third of it, right down the spine of the house. The floorboards were nailed straight to the joists compressing the insulation and causing a cold bridge from the 18mm flooring through the joists to the ceiling below. Not the most ideal thermal solution. Cleared the loft of everything but the spiders and measured things up.
s!Ahf7xhLzGq1Qr0l1Xu1Ae_RVuI02
I mentioned truss uplift earlier - I searched on seasonal cracks appearing and that’s what popped up more often than not. My surmising is that in the winter the joists to the left and to the right of the loft flooring are all cosey and warm around the 325mm of insulation but the centre of the joists are connected to a massive block of cold flooring. This disparity across the span of the joists causes them to contract in the centre and lift. We’re talking only a millimetre or two of uplift in my case but I’ve seen some examples of it being over 10mm!
This is an exaggerated interpretation of what I mean:
s!Ahf7xhLzGq1Qr1qCn-tdggNvQV7V
The solution is simple – remove the cold bridging and insulate the length of the joist spans to the same degree by removing the existing floor and laying more insulation down, making sure the new floor doesn’t compress the insulation. I’m going to lay 200mm insulation which matches that of the insulation to the right and left.
Issues 3 & 4 – A couple of things can be done for this. Firstly, is to make sure all the soffit vents are clear of insulation so that air can flow freely. Secondly is to make the new loft floor high enough so that air can flow under the floor and any cold bridging between the flooring and the ceiling is removed as best as it can be.
I looked at the options for raising the loft floor and decided on the system from LoftZone. The supports/legs are 279mm tall so with 200mm of insulation underneath these would give plenty of separation between the insulation and the flooring. I also decided on 22mm thick flooring rather than the 18mm fitted previously.
I just needed to work out how many uni-supports, tri-supports and crossbeams I’d need, not forgetting the floorboards. To the SketchUp!
s!Ahf7xhLzGq1Qr1s2Iu86WJnowt_t
I also used the SketchUp model for the best positioning of the LED battens which I increased from three to five. Light is good.
That looks like quite a lot of supports....
s!Ahf7xhLzGq1Qr13e26kqN8VTzK0R
So I'd need:
  • 70x Uni-supports
  • 40x Tri-supports
  • 35x Crossbeams (1.8m long)
  • 21x floorboards (2.4m x 600mm x 22mm)
  • And a lot of screws. Not nails. Definitely not nails. Nope.
And lastly Issues 5 & 6 - the extractor fan and ducting. This is what I found after I lifted the flooring adjacent to where the previously fitted in-ceiling extractor was fitted:
s!Ahf7xhLzGq1Qr1jb6fdZL6el1nmJ
Yuck.
s!Ahf7xhLzGq1Qr1koFR3WPCNl8gCE
The plan here is to reroute the fan ducting so that it's length is under and in the insulation and the fan is to be mounted on the gable end wall with a condensation trap fitted to vent it out a pipe in the wall. A bit like this:
s!Ahf7xhLzGq1Qr0uvOSY-VcFxhppM
Rather than go out through the roof the exhaust will use the pre-existing hole I made for it a while back. The pipe on the right of the image close to the floor is what I'll use to expel the condensate.
s!Ahf7xhLzGq1Qr142qtBaGNM01rcX
So that's the plan. I've done some already but still waiting on certain items, deliveries can take ages where I live.
I've used the loftzone system before its quite good. I'd just use the existing 18mm floor unless it's mouldy. You'll still have point loads in the ceiling where it's tied to the truss.
Have you considered doing a proper conversion even if only for storage?
Very nice size and looks like those trusses could be removed.
I'm glad you think well of the loftzone stuff, hopefully it's cost is justified. I considered reusing the 18mm board but it was a bit warped from being damp I think.
s!Ahf7xhLzGq1Qr2B3JElNyoM72BTL
It also got a bit wrecked when taking the nails out, especially when the damn head break off. Then I have to dig them out with the multi-tool. I swear this has happens in about 1 in every 5 nail.
s!Ahf7xhLzGq1Qr2GFDC8_u2WymTAf
I decided that the existing flooring was of no use to anyone and I needed to get them down from the loft. They are much more manageable at 800mm long rather than 2.4m lengths so used my new toy (I mean tool, every project requires a new tool right?!) and ripped 3 boards at a time in to thirds. This circular saw is a beast!
s!Ahf7xhLzGq1Qr2KLgnz1PiV0Fxch
I did think about it because it would make an awesome space but the cost of it was prohibitive, somewhere between £50k to £100k. It probably wouldn't add anything to the value of the house either.
are you upgrading 18->22 just for stepping around / dynamic load ?
otherwise, do the underlying ceiling joists and their strength/span justify it from a pov of weight of stuff you might store/m2
Has the insulation significantly bounded as the top is removed
its a loft used for storage, I would use any old chipboard I could.
The only reason I would dispose of the chipboard you have is where it has got mold on it.
I had to buy chipboard for our loft as I didn't have much, but i defo wasn't happy about it, I go up there once every 2 or 3 months for 10/15 minutes max (usually for 2 minutes or less) anything i put up there is almost wasted money in my eyes.
To be honest I saw the state of the existing 18mm flooring with it's bowing and warping that I decided to replace it with thicker boards. Perhaps overkill and wasteful but I wanted it to be right and never done again.
You mention the strength of the ceiling joists and the weight of stuff that will be stored there. I was concerned about the weight of the supports, beams and boards with their total weight of 556kg although some should be deducted for cutting boards around the chimney, loft hatch etc. Given there will be 110 points of contact, the size and spans of the joists, I feel it's sufficiently spread out and will be far lower than the 25kg/m2 standard for permanent loads in loft floors. Ironically, since clearing the crap out of the loft and binning a significant amount of it a lot less is going back up there - but you never know what'll go up there in the future.
The joists aren't exactly equidistant but I plan to space the crossbeams equally.
s!Ahf7xhLzGq1Qr2Q6160rBMDY-oGv
The existing insulation has certainly started to decompress (is the word uncompress? bound? lol) as the old boards are removed without any "fluffing" by me. With the 200mm going on top of this it should be a noticeable improvement.
s!Ahf7xhLzGq1Qr2PwCBvuY5SkW_kG
I totally understand.
A little update while I wiat.
There are so instances of this where whoever laid the previous loft board notched the joists for the cable but then used screws to hold them in place. Did they not think?
s!Ahf7xhLzGq1Qr1P9YpfkjfR4n7Hu
I'll be careful removing these and checking for any damage to the insulation (of the cables).
s!Ahf7xhLzGq1Qr1KpEgYCNxhjTpTM
Next little job is to make sure all the eaves and soffit vents are clear of insulation as most of them are not.
s!Ahf7xhLzGq1Qr2flM_L2wN58GdUX
Now I'm just waiting on the LoftZone delivery as I can't progress any further. I'm a bit annoyed as I ordered the stuff first thing Monday morning this week and today being Friday means if it's not here today it'll probably be next week.
s!Ahf7xhLzGq1Qr2iKc2a09mixoHmP
what is their dimensions - do you attach the legs to them first, and then upturn and screw it all down onto joist.
if they are 4x2 laying on their sides , then is that really optimising height and strength versus a grid of 2 levels of 4x2 stacked to 8" (which would weigh more)
was wondering about using material like we have on office floors https://www.buildingmaterials.co.uk/caf600-office-grade-panel-598mm-x-598mm-x-30mm-pack-of-10-3-58m2
presumably you wacked nails from the other side too, too remove them - seems a lot of damage
The crossbeams are thin galvanised sheet metal that's bent in a C shape that slides over the supports. The idea is to fix the tri-supports (or uni-supports if it's not possible) to the joists first then slide the crossbeams in to position, then screw the beams in to the supports.
If you have 30 minutes to burn here's their training video that explains it and more.
No, all the nails were taken out from above, the ones which their heads broke were then dug out with the multi-tool and yes, it did make quit the mess getting them out!
