Apparently it was introduced at Spa, but doubt it was used at Zandvoort or Monza.It's entirely possible their wing has been doing this all season but nobody has paid attention until now they're winning
Oh I'm well aware that the flap opens and closes, I just had in my head that the McLaren flap in particular had bottom corners that angled up slightly relative to the fixed side parts of the wing (the split yellow lines that Kenai drew). I must be misremembering and thinking about the view with DRS active and the flap fully open.
I wonder what people who think this was a boring race want? The first part was slow, I'll give you that, but from there is was a banger only mildly spoiled by a clumsy incident ending a cracking wheel-to-wheel end race battle for podium places.
but isn't that every single F1 thread, the same people coming in here week after week complaining about the same thing, yet they keep watching, and then keep coming back here to complain.I suppose there are those voting who will compare it to races of all time, so for them, even the best races of this season will still be a 6/7 maybe? I try not to take it too seriously but, if you are voting that as less than 7, I'd possibly give up watching F1 as you aren't going to realistically ever be satisfied with what tends to be served up these days.
Ah got you. Hard to tell on the internet!Sorry, I didn't mean for my reply to come off that you didn't know it opened and closed haha! I was explaining the mechanical and external composite structure requirements (towards the end plates) needed to match said central mechanical fixing, so the slot gap remains even and legal across the whole wing (i.e. no flexing towards the edges of the flap, like in the images and videos we've seen so far).
It could be down to how the wing is build in terms of the carbon fibre layers or whatever other composite material they might be using. The edges could be thinner/more flexible and therefore deform (intentionally) under load. So it may be that the edges aren't tested.Ah got you. Hard to tell on the internet!
As the actuator is pushing it closed I wonder if there's any point at which applying more pressure pushing on that middle point starts to flex the wing itself, beyond any FIA load tests? Seems like the only way to do anything mechanically that could be applied during the race otherwise it's reliant on the force of the airflow over it. If it's something I can think of then I'm sure it's been tried.
Interesting if it was introduced in Spa. I'm sure someone willing to put more effort in than me can gather up a few onboard clips before and after to see if there's anything new going on![]()
Yeah that's what I meant when I said would reliant on the aero load (which I do think is most likely btw, it's been common practice on the front wing for a long time so why not try it elsewhere).It could be down to how the wing is build in terms of the carbon fibre layers or whatever other composite material they might be using. The edges could be thinner/more flexible and therefore deform (intentionally) under load. So it may be that the edges aren't tested.
I think it's exactly this. It also means it's so difficult to test/check this sort of element because when they doo look at a car during parc fereme to check, it isn't travelling at 300kph...Yeah that's what I meant when I said would reliant on the aero load (which I do think is most likely btw, it's been common practice on the front wing for a long time so why not try it elsewhere).
FIA: "We don't allow any moveable/flexible aero".![]()
FIA release statement amid fan claims that McLaren should be disqualified from Azerbaijan GP after unseen footage emerges
The FIA have released a statement on the status of both McLaren cars amid fan calls for them to be disqualified from the Azerbaijan Grand Prix.www.sportbible.com
Also the FIA: "Steve sat on the wing and that's good enough for us".
They'd have to bend otherwise they would just snap.Not really, they have a defined set of pretty rigorous tests. Like anything else in F1, the good designers draw into the gaps those tests create for their benefit.
Ultimately, things bend, so they define "not bending" as doesn't bend more than a specific amount under specific loads at specific points.
Absolutely, the material is inherently flexible, and the FIA have allowances for how far each part can flex (to prevent teams from overreaching), but the DRS flap opening at high speed is not right.Not really, they have a defined set of pretty rigorous tests. Like anything else in F1, the good designers draw into the gaps those tests create for their benefit.
Correction, every team capitalises off loopholes and still do, Brawn did it with their blown diffuser and Mercedes did it with their DAS system.All part of F1. RB have capitalised off loopholes for long enough. Now it’s the turn of another team.
I'm all for innovation and the general tech behind F1. Also have no issue with Oscar winning so it's purely about the FIA being consistent. They shouldn't be banning anything mid season if it's not specifically in the rules, which they have done.Then they should introduce some new tests and give them some races to introduce replacement wings, as they've done before.
Either way, the wing is legal and if McLaren really are getting an advantage from this gap then good for them.
Did they?All part of F1. RB have capitalised off loopholes for long enough. Now it’s the turn of another team.
