- 28 Dec 2017
- Beds
It IS well hung. I'd be proud too.Gate seems really enthusiastic (- and proud of how well you've hung it!)![]()
I wonder how long the gate took to erect?It IS well hung. I'd be proud too.
Are some of those bricks sagging? Weeds and sagging... That driveway isn't that old is it?Patio Magic on the drive following 6 buckets of weed pulling. The weed membrane has been nailed by some of the larger weeds. Maybe I'll fork it over and level it off a bit before membraning and barking.
Maybes I'll just do this same thing again next year.
No sag but a handful of bricks have shifted. Weeds is expected as it's block paving.Are some of those bricks sagging? Weeds and sagging... That driveway isn't that old is it?
Changed 3 of the radiators upstairs in the bedrooms. The rooms were a little cold during the winter so i have put in bigger ones, sized for a heat pump in the future. Then i cut the grass![]()
Chauffeured the Wife, middle daughter, mother-in-law, sister-in-law and niece to a Spa Hotel for the weekend
Wonderful -Thank God - I thought the wife was the only one to use all pot's -pans -dishes -cutting knives -dessert bowls -jugs -cutting boards - cups -whole role of paper towel- 25 bowls of fresh water -spoon's - this is just to feed the cat.Chauffeured the Wife, middle daughter, mother-in-law, sister-in-law and niece to a Spa Hotel for the weekend, then got home to do a few little snaggy jobs (cleaning up filler/caulk, scraping paint flecks) before getting on with laundry (uniform & pe kits for next week).
Cooked steaks & homemade chips in the air fryer, with fresh salad, peppers & cherry tomatoes from Dad's allotment, for the three of us (son & youngest daughter), but still managed to dirty every pan & utensil in the kitchen...
...then discovered the Wife had used the last dishwasher tablet that morning![]()
I clean as I go, but have preferred kit for different recipes - so Steak & fries will use one set of knives/chopping boards (separate meat/veg), marinading bowls, whilst a Thai Green Curry uses other stuff (Santoku/Chinese Cleaver, Wok, Rice Cooker).Wonderful -Thank God - I thought the wife was the only one to use all pot's -pans -dishes -cutting knives -dessert bowls -jugs -cutting boards - cups -whole role of paper towel- 25 bowls of fresh water -spoon's - this is just to feed the cat.
She is cooking dinner now -long cooked leg steaks. so that is another dish.
No pipe adjustment, just drained the system, new valves, fill, leak test, drain again add inhibitor and bleed everything. Didnt want to change the valve but 2 of the lockshield had seized and one of the thermostatic has also so i thought I may as well do the lot.3 rads in one day is good going. Would probably take me a week! Or did you not have to adjust the pipes?
Ahhh, peace and quiet in your house, beautiful.
I'm not an expert (only fitted one gate before!) but I'm not sure on that bracing, should it not be "toe and heeled" from the hinge corner (bottom right) up to the top left to prevent sagging? I've not seen that method before but doesnt mean its not a reasonable solution
Ah I think you want something more like this (my previous one). If it sags I guess you have the know how to modify now!I'll be honest I have no idea. I basically built the frame round the outside the suit the cladding being attached and then stuck a bit of wood in the middle hoping it would keep it squareI guess I'll find out!
Them be some fine looking hinges there. Pass me the tissue box.Tis the season for gates, these are mine this year.
