- 19 Oct 2010
Yeah. Thats been used well.
It isn't really cold enough, more miserable. Low teens and raining, So I thought why not.Nice!!
Don't think ours is far off !
No.
As far as I’m aware they’re only being banned in new builds.
does anyone bother sharpening their chains, or do you just buy a new one every so often. Seems like quite a faff to sharpen a chainsaw chain.
There’s a Stihl 2 in 1 chain sharpening tool which makes it a 10 minute job.does anyone bother sharpening their chains, or do you just buy a new one every so often. Seems like quite a faff to sharpen a chainsaw chain.
Thanks. You're the second person to recommend one of those, so I've added it to my shopping list.There’s a Stihl 2 in 1 chain sharpening tool which makes it a 10 minute job.
You can cut a whole load of wood before you need to give the chain a touch up unless you hit metal or stone with one.
Make sure you get the correct one for your chain’s pitch - there’s 3-4 common sizes for Stihl saws.Thanks. You're the second person to recommend one of those, so I've added it to my shopping list.
Nice- but did it go out - There is only one picture.First burn of the year.![]()
It did at 22:30 after I'd closed the air off.Nice- but did it go out - There is only one picture.
Why are you using Wera screwdrivers to poke the fire. -heathen.![]()
Sensible decision.Someone mentioned the ban the other day but seems Scots can have them "again"
Ministers pause ban on wood burning stoves
New restrictions were put under review after concerns about their impact on people living in rural areas.www.bbc.co.uk
