Horrific ride at lunch. I was woken up a couple times in the night by the wind, and it's continued today. At one point my garmin suggested i was doing 300w, on a slight downhill and still only doing 13mph due to the headwind!
I used them this evening on mine and actually they were fine. My fan and trainer are reasonably quiet thought I suppose...maybe the ambient noise from drivechain/trainer will be too much.
any updates on TCR ?The frame saga continues...
I cut the ISP to the right height on the new frame and now the topper doesn't fit very well. It was a decent fit before I made the cut and now its sloppy. The cut I made was excellent and after sanding is perfectly flat. Flatter than the top of the uncut ISP. The issue also isn't with it rocking which might have suggest a wonky cut.
You would think this would be one of the few areas on the bike they would take masses of care with because its the single most likely point of failure and warranty. Going to call up the dealer today and see what they say. If they say just tighten it and ride it I will but I want it on record so that if/when it damages the ISP from movement I have proof I told them about it and it wasn't "user error".
I just want my fancy bike back!
Careful where you stand on the pavement.It would seem that Van de Poel is at that event i'm signed up for, albeit the "pro" event the day before. I've got to head to registration though so will see if i can find a good spot to watch.
Although I'm in a garage so doesn't really matter about the noise/music I do prefer headphones... Bit more private! Also need a mic - leading TTT's and racing Ladder races need to be able to communicate.No option to just use a Bluetooth speaker?
Fair enough, pretty much why I've gone Di2 - moving from mechanical 11s means easy swapping of components (cranks/cassettes/chains) but now I'm back to where I kinda started with 3 bikes on 11s, 2 of them being Di2 and a 4th being 12s Di2 which isn't back compatible!@Roady mainly cost, availability and cx. Cx bikes don't come with 1x di2, so I'd have had to buy something then swapped out the components. Sram axs is generally pretty good I've found with my boardman, and like before when I had everything 11s di2 I only need to buy one type of chain and cassette to have as spares and all my wheels and cassettes are now completely cross compatible.
First world problems!
Thanks for the feedback & 'review' - really what I was after. Think in/on ear for the volume side of things is going to be key for me (although my trainer isn't loud my drivechain isn't quiet).I'm thinking it probably will. I'll give mine ago on the trainer, maybe tomorrow, and report back. I know when I use these for watching TV and I go and wash a dish in the sink, I can't hear the Shokz over the noise of the tap/spray. I'm a little concerned these ones might be worse for cycling with wind noise, but we'll see.
Yeah thinking more like they won't be loud enough. A big part of my riding (leading TTT's) means I need clarity both side (hearing others & my calls to the team).I had the shokz titanium's and had an issue out of waranty and got a reduced price upgrade to the open run pros. The sound was a good improvement agaisnt the titaniums. Indoors on the turbo the sound is ok its more than enough to take your mind off the pain on hard intervals thats until the fan is on max then the sound is a little faint but its still a help take your mind off it level.
It was actually a glorious Saturday here, typical I had a funeral to go to so didn't get out. Got a bunch of house chores done and some preparation for a new garage roof going on... Typical it rained nearly all of sunday when I had time to ride, so my only option was Zwift.
Glorious day here again today to be sat at a desk... Rain scheduled to return 4-5pm for the commute - as expected!![]()
I'm still very much in "trying to get my legs back" phase so short rides at lunch work okay. I'm sorta hoping I can get fit/fast enough to get 20k ish in an hour during lunch. That'd be perfect.It was actually a glorious Saturday here, typical I had a funeral to go to so didn't get out. Got a bunch of house chores done and some preparation for a new garage roof going on... Typical it rained nearly all of sunday when I had time to ride, so my only option was Zwift.
Yes but I didn't for a long time. 40nm is tight. Not yard on it tight but give it a bit of grunt. I think if you give it some beans its unlikely to come loose. Just check on it after you have ridden it for a bit to see if its come loose at all.Does everyone have the relevant tools to put a disc on to 40nm, or do you just put it on 'tight' (I only have a small torque tool for the 4 and 5nm bits)
Why not the new equiv tcr?
