Yeah sorry that's the one, I just misread the nameMoraroy? If so then I’ve just had a quick look at it and it uses Non Steam Launchers. I’m not 100% clued up on the situation nor have I looked into what Moraroy does but NSL can apparently cause problems due to how it sets up each launcher with Proton so be aware.
They are the standard launchers but they are configured on the deck in such a way that they are all shortcut and ran from the "non steam games" section of the library and they are in effect full screen pop up windows running as an application I guess.
Wouldn't say I was at all the authority on the stuff but what I have enabled so far seems to work pretty seamlessly. Having then chosen the launcher remembers your credentials makes everything easier from the logon perspective as you then open up in to that library etc.automatically. makes it feel a bit more seamless.
I think that due to the way launchers work they will.never be seamless but it's giving the desktop pc experience that the ally etc. all would give on the deck which is cool.
Just been good fun so far working out how flexible the SD can be outside of its core abilities
