- 23 Mar 2011
I like this!Took a trip to goodwood and couldn't resist, also had a really good chat with Luke from the autoalex youtube channel, sound bloke!
I really want to do this next year @MrRockliffe. Did you combine it with any other trips? How long were you out there?
Thanks mate. Appreciate that! I'm a member of "BMW Performance Car club" and they are setting something like this next year! Anything you would have done differently?
I should really get round to posting my 21-year-old rot box on here. Slowly getting back into the forums after a long time away!
Lovely looking car - but those wheels look comically too large, almost monster truck/hot wheels esq to me.Phat parking….
Well, it's about time I posted the money pit...
2003 BMW E46 M3 in Silver Grey.
I've owned my poster car growing up for just over 5 years now.
I bought it as a project, and it needed considerable work. It's taken almost 3-4 years of pain to get to this stage, but we are almost there. I've built it for fast roads and tracks and managed to make some epic memories with it, including taking my three boys to the Ring for a few laps!
- Brands Hatch Track Day
- Spa Experience day
- Nurburgring Ring TF (5 trips to date)
- Nurburgring GP Track
I've raced Karts since I was 11 and over the past 5 years competed in some MSV Events, Enduro KA. I've stepped away from racing competitively and this seems to fill the void!
Engine Mods
Eventiuri Carbon Intake with cold air feed
PS Designs Carbon Fibre front air RAM
Full Headgasket completed in 05/24
DO88 Performance Engine Oil Cooler
DO88 Performance Aluminium Radiator
Vanos Overhaul 24/05 with VAC S54 UPGRADED VANOS HUB
VAC Oil Cap
Suspension / Handling
Vogtland Coilovers - To be replaced with full coilovers '25
H&R Antiroll bars front and rear
Tuner Adjustable rear arms
AP Racing 356mm 6 Pot Front Calipers Powdercoated in Silver
AP Racing 4 Pot Rear Calipers Powdercoated in Silver
Pagid RSL29 Brake pads all round
BMW Purple Tag Steering Rack (Shorter Clubsport Rack)
Solid Steering Coupler
Wheels and Tyres
18" Apex Racing ARC8 Staggered setup
Michelin Cup 2 Connect Tyres
PS Design Titanium Stud kit
Interior
BMW Imola red interior complete with OEM factory fit Tape unit (In use!)
OEM Steering wheel recovered in alcantara with red strip
Paint / Wrap
Silver Grey Paint
Bodywork
Carbon Fibre Front splitter
AGT Carbon Fibre side skirts
CSL Carbon Fibre Rear Defuser
Rear arches were cut out, replaced, and rolled in 2019
Lovely!
Reminds me of my CSL and my track built M3:
When properly setup they are such capable track cars, rebuilt engine myself on it as well as it spun a bearing, car is in Ireland now and still going strong!
Fantastic. Yeah, when set up - incredible cars on track, the connected feeling is something else! Photo looks great mate!
I had my Rod bearings replaced shortly after my subframe work! I Was worried about it up until then! The head gasket was done this year and took the opportunity to replace all of the cooling system at the same time. Getting to the age now, if it's not been replaced - it needs replacing!
Did the engine need much @Gibbo ? assuming full rebuild? How many miles were you at?
If used regularly then money pit isn't even a baseline for costs lol, it's beyond money pit as far as E46 M3s go. 9 years owning one including an engine swap due to rod bearing failure and tracking every cost has been mind altering.
Can't beat the experience of the lightning throttle response, carbon induction and how planted and connected you feel with the road though.
Bearing shell failure is completely luck of the draw, you either hear some knocking and stop in time if driving around town, or hear zero knocking and you'#re at motorway speed and suddenly power drops massively and you coast to a stop which is what happened to mine. It was on original bearings on that engine which were recalled/replaced by BMW years later with an updated version. My donor engine with half the miles was installed by Redish and bearings and all accessories replaced on that whilst I also had a new clucth and flywheel + accessories installed.
It was cheaper to get a donor engine than to do a rebuild at the time due to the labour hours needed to get it done properly.
100% this.This I could never recommend an E46 M3 to anyone, the list of issues is endless:
- Rod bearings
- Boot floors cracking / rear subframe
- Vanos issues
- Rear diff failing
- Poor factory brakes (expensive AP kits the solution)
- Oil leaks
- Head Gasket failure
The age they are at now any car with 80k plus miles really needs all the above sorting which is just on top of regular servicing/running cost which don't necessarily come cheap, worth it though they are fabulous cars and kudos to the owners still running them and keeping them going. Superb cars when running healthy and setup right.
