Intel Core Ultra 9 285k 'Arrow Lake' Discussion/News ("15th gen") on LGA-1851
In terms of power consumption over time it is actually far more complicated - when you factor in whole system power consumption and PSU efficiency, etc. and that Intel is actually more power efficient in the lower half of utilisation states the actual power use over say a month of usage can be a different story. If you are spending many hours a day gaming that is one thing, more mixed use especially if the system is sitting in lower idle states a lot can be another story again.
Intel are not more power efficient though. How many times have we been over this now. Outside of you sitting and monitoring your gimped systems idol power use AMD are miles ahead of Intel in power efficiency. AMD are literally 3x the performance per watt or more.
A lot more to this - the benchmark tests, aside from idle, are usually canned benchmarks at 100% utilisation, and power is often measured from the CPU rather than full system. Intel's power gating is more advanced than AMD's - in the lower half of utilisation states Intel actually uses less power than AMD. When you look at the picture for real world day to day running it becomes more complex.
To be fair, these are the same people who are willing to buy the latest Intel chip after the last 2 generations literally melted.
Only in cloud cuckoo land. You’re talking around your hat again.
Afraid that is you. If you have an AMD 7000 series system with a 14th gen side by side and measured power use over a whole day you'll find the results vary a lot depending on what you are doing - under high load conditions AMD have better power consumption but under idle conditions (that doesn't mean doing nothing at all but light office tasks, even just moving the mouse or other applications which put up to moderate load on the CPU) Intel are better.
You're wasting time on this one.
Reading all these comments and the general consensus is that I'm better buying the 14th series for a new gaming pc?
Why would anyone consider buying a 14th or 13th gen when they are proven to be flawed given recent events? Is the risk realy worth it? And then there is the power consumption and thermals...
Stick with what you have, then see reviews. I'm firmly staying put with the 12700K until a platform update that comes out that is actually next gen now. The 4090 is happy at 4K as long as a CPU is somewhat capable and evidences by all benchmark results for games and 3dmark etc.
Problem with that is the 14th gen is a dead end socket as the new processors are socket LGA1851.
Not sure anything right now really shines for future proofing, LGA1851 isn't exactly generous with extra provisioning of new features and new technologies are likely just around the corner like PCI-e 6.0, etc.
According to some users Intels failing CPUs are down to propaganda from the media.
(Inserts nothing to see gif)
I haven’t seen any of the reviews yet, but let guess. More, more of the same with bells on?
We barely have anything that takes advantage of PCI-e 5.0 other than some top end hard drives. No GPU's currently use 5.0 bandwidth
I don't think people need to be too concerned about not having PCI-e 6.0
Can't compare an e-core to a full fat core from AMD. Obviously a gimped core will use less power, but as soon as you do anything meaningful, it's down to how optimised the scheduler is, which Intel have struggled with since the introduction of those e-cores.
Makes sense,will also wait for reviews
all my systems never sit idle. they are either on (working) or off as I don't like wasting power! Further more the systems are switched off at the wall as even the PSU consumes power even though the system is off. A PSU to match the power requirements of the system is also important to me. A large PSU is extremely ineffecient at low power.
I know exactly how much power is required as most machines are solar powered. Current Intel platforms are only heaters in my view.
What ongoing struggles? A few games had issues at launch, the games were patched, problem solved, this was ages ago. Can you elaborate? At present there is no game or app that I am aware of with issues due to E-cores.
Huge shadow over them with the issues - but I'm yet to see them impacted on large scale in the real world, though not enough time has passed to see the full truth of it and not enough clarity from Intel to be sure. From my experience so far it seems that the problem CPUs are [probably] a relatively small number which are incorrectly boosting beyond 1.5V.
I've been running, and not treated gently, a 14700K from launch without a single problem so far and I don't find the thermals (running air cooler as well) or power use that bad - it runs far cooler, far less power use and not that far behind for performance compared to the 14900.
PCI-e 6.0 was just an example, but we are due iterations on quite a bit of tech which will make most existing platforms obsolete if people care about future upgrade paths, etc.
Not a big fan of e-cores personally but I've had zero problems with my 14700K and Windows 11 in that respect, some people have had issues especially with Windows 10. There are 1-2 pieces of software it is apparently still an issue like Star Citizen but I don't use those to see. But in that respect there is still a similar story with the split CCD AMD CPUs, again mostly edge cases these days but still some scheduler issues.
