The first part of that says principle number 1 is: "the user is always in control", I wonder how that tallies with automatically uploading your files to OneDrive and ignoring your preferences to randomly reenable things whenever MS feels like it?![]()
Update on Recall security and privacy architecture
Overview As AI becomes more integral to Windows, Microsoft is doing more with AI on the edge with the power of a 40+ TOPS Neural Processing Unit on Copilot+ PCs. This enables lower latency, better battery life for AI intense tasks, use of AIblogs.windows.com
TLDR: it's opt-in
While MS could be lying, I'm not going to take the word of some random utuber either. I'll just wait and see. I'm dual booting so can nuke 11 at any point.![]()
I must be dumb, but I don't understand why recall has to be integrated into file explorer, doesn't it just take screenshots? It seems pretty sinister that it is embedding itself into the OS like this, like a spyware that even if you flip the switch is still operating and you have to take it on trust that there's nothing sinister at the other end.They pulled the it would only work on AI PC's, now its opt in and the video above now says its intrgrated in file explorer so expect it to be enabled by default soon or an Windows update/setting will accidentally turn this on.
Like their latest/new verson of Edge is integrated into Windows as it cannont be removed offically and removing it via other means causes a number of issues I guessing recall will follow the same path.
Not sure that's just a Windows 11 thing as i noticed, after running my usual disk cleanup after patch Tue, that there's also 304MB of updates on Windows 10 that are undeletable.![]()
Windows 11 24H2 issue creates undeletable 8.63 GB Windows update cache
Windows 11 24H2 is doing well with fewer issues than previous updates. However, there's an 8.63GB update cache issue.www.windowslatest.com
I see the 8.63GB in both areas too. MS are fixing it for the next update.
Dism.exe /online /Cleanup-Image /StartComponentCleanup /ResetBase
Using the F10 route takes about a minute to do and such a quick workaround, but like you said people who buy new PCs etc are not going to be aware of this and causes everyone a headache.One of my acquaintances said where he works they are getting loads of customers returning systems the last few weeks due to Windows 11 getting stuck at the "Let's connect you to a network" screen on first run, even on pre-built systems, where it can't load the network driver or connect to WiFi and the average consumer doesn't know enough to fix or bypass it. They are getting quite fed up with it.
Your acquaintances at work and everybody who worked at technical support must be felt ashamed of themselves. There was absolutely no need to returned systems, I felt awful for these poor customers paid expensive £50 delivery with cover for systems valued £1000, £100 delivery with cover for systems valued £2000 and £250 delivery with cover for systems valued £3000 could contained RTX 4090 etc. Your acquaintances at technical support should gave customers very simple correct advice to fix Windows 11 getting stuck at the "Let's connect you to a network" screen issue with 3 methods.One of my acquaintances said where he works they are getting loads of customers returning systems the last few weeks due to Windows 11 getting stuck at the "Let's connect you to a network" screen on first run, even on pre-built systems, where it can't load the network driver or connect to WiFi and the average consumer doesn't know enough to fix or bypass it. They are getting quite fed up with it.
Doing this many times will soon add up on the total time to "fix" an issue which is not their problem.
Somewhat missing the point that none of these should be necessary.Fix 1: Press Shift and F10 or Shift, FN and F10 or Shift, Ctrl and F3 or Windows key and R to open command prompt. Type in taskmgr and press enter, task manager window will open, click on Network Connection Flow and right click to end task it.
Fix 2: Press Shift and F10 or Shift, FN and F10 or Shift, Ctrl and F3 or Windows key and R to open command prompt. Type in OOBE\BYPASSNRO and press enter.
Fix 3: Press Shift and F10 or Shift, FN and F10 or Shift, Ctrl and F3 or Windows key and R to open command prompt. Type in cd C:\Windows\System32\oobe and press enter. Then type in OOBE\BYPASSNRO and press enter.
If I'm now expected to have to Google random issues during Windows setup, then I may as well be using LinuxAverage customers like me should know how to use a mobile phone and google it or use youtube to find solutions for Windows 11, Android and Samsung Galaxy S24 issues.
Microsoft with a market cap of 3 trillion dollars: Use Google or Youtube to fix your problem because we can't.![]()
It's definitely here to stay,it's the future they'll be able to collect and determine so much better targeted ads and what people look at using Ai.I hope AI is a bubble and it pops soon (probably not though).
I best start looking for an alternative to TCP/IPIf you're still using SMB1, a 40+ year old protocol, maybe it's time to upgrade your network.
