smoke and mirrors should be up to speed pretty much as soon as installed. Engineers say 'it will take time' because they are pushed with their work load and need to get on to the next job and do not want spend time diagnosing or don't have the skills to diagnose it... complain and if no resolution quickly you have 14 days to cancel from installation.. I have seen so many stories on various social media about BRSK customers getting nowhere near the speed they have paid for but to be fair a lot of happy customers too, but the ones who are unhappy do seem to be given the run around and fobbed off.Hello fellow BRSK users, I had BRSK fibre installed and activated yesterday, 150 Mbps upload and download.
Unfortunately I am only getting between 6-26 Mbps upload, the BRSK engineer said it might take a couple of days to settle.
I have already contacted support and was just given basic instructions, which I already had tried.
Just wondering if anyone else's BRSK fibre upload took a few days to settle down and reach the full speeds.
Thank you, I have sent another email to support with todays slow uploads, if I don't get a reply soon, I will threaten to leave.smoke and mirrors should be up to speed pretty much as soon as installed. Engineers say 'it will take time' because they are pushed with their work load and need to get on to the next job and do not want spend time diagnosing or don't have the skills to diagnose it... complain and if no resolution quickly you have 14 days to cancel from installation.. I have seen so many stories on various social media about BRSK customers getting nowhere near the speed they have paid for but to be fair a lot of happy customers too, but the ones who are unhappy do seem to be given the run around and fobbed off.
Hello Spudmaster, download speeds were the full speed straight away, it's the upload speeds that have been a problem.As already speeds were full speed pretty much straight away. Are you testing speeds using cable or WiFi? What download speed are you getting?
Just done a pre-order for this whilst the offer is on with someone's referral code on here so hopefully we will get some vouchers
It's not available where I am yet though so god knows how long it will take.
Longtime lurker.
I currently use Plusnet FTTC which does not use CGNAT. I do not have a static IP address from them.
I use a Raspberry PI to create my own VPN, which then allows me to securely access my home network when travelling. I use a commercial dynamic DNS service to provide a stable URL address for the VPN. I forward a port to the Raspberry PI (it uses a fixed internal IP address) using my router's (a proper retail version, not an ISP cut down one) configuration.
All works totally fine.
However if I switch to BRSK (they're currently trying to sell their packages), will CGNAT break that setup, and if so would their static IP add on work to fix that?
Obviously the sales people were unable to answer that as it goes beyond their authorised script. My knowledge of network configuration is maxed out at the above.....
TIA.
Not when CF does 3Gb for £56 each month. But BRSK are installing where they havent got much competition as of yet, so can charge this amount.If someone truly needs 2Gbps then £55 is a complete bargain
What do you have now?mine gets installed on tuseday was thinking should i get a better router
it was a normal modem/router not one for fibre iv bought the asus ax6000 iv got it working the speed is fine but the data led on the brsk box is orange and not green and i dont know whyWhat do you have now?
ah no way lol so nothing to worry about then?2.5GbE connection, instead of 1GbE
