A combo product that tries to clean and protect is usually a disappointment.
Always get discrete products for something with such contrasting tasks.
It'll be fine I'm sure.I need to buy a DA polisher. I don't want to spend more than £100 including the backing plates and a set of pads. The In2Detailing ones look good for the money. I'm only going to use it a few times a year so is a 750W one powerful enough? I won't be doing a full paint correction, only removing swirl marks.
This is the one I use: https://www.amazon.co.uk/Ginour-Polisher-Detailing-Variable-2000-6553RPM/dp/B07SQQ4JWQ
I'm sure it pales in comparison to professional grade DA's, but if you're only planning to use it 2-3 times a year then it does the job admirably.
Tbh if it works as it should, it’ll do the job. Easy to get caught up in carbon fibre, cordless machines costing £700+
Reality is, they won’t make you any better![]()
Good stuff is still good stuff. If it still works, and you enjoy the process of application, then just do it. Nothing wrong with that.Do people still hand wax their cars anymore or is it all done with machine polishers nowadays?
Just found a 2.5L bottle of MER car wax in the loft in a box of car stuff, it was supposed to be a decent product in its day.
I remember buying it on a day out to the Ideal Home Exhibition years ago.
Is there any use for it or waste of time messing around with it?
Thx
Question about the throw size of random orbit polisher if anyone can please help?
Looking at a few DA polishers the throw sizes seem to be either 9mm or 15mm, what is the difference in these when translated to real world use on a car?
Thx
These are excellent for the money. I use them for the grotty bits like wheels, door shuts etc. I got a 6pk from ebay for 15 quid a year ago.recommend me a small Drying Towel
i love my Turtle Wax one (Rag company one) but its sooo big ! amazing though
want to get a smaller one for lower half of car and wheels really
About 5 weeks since the last wash and it was well due...
Just a standard wash no frills. Garage therapy shampoo, basic hose and one bucket. Another bucket and mitt for the wheels.
found some elbow grease shifted more than just having fun with the pressure washer at times
