or about 5 leather jackets.
whos got 1300 to spend on a motherboard? what is going to get super expensive next.
we can be glad soundcards have fell off
switch to another brand that doesn't have stupidly expensive lineups, lets face it you won't evet know the difference anyway.Motherboard vendors last ditch effort to rinse the public, it's honestly really disheartening as a customer.
"If you need to ask how much, you can't afford it"
Unless you go very lower end you don't get any different CPU performance, not sure what other features would warrant so much extra cost
With retailer you can buy for 425?Ryzen 7 7950X3D is £425 if you have a look around.
90 USB Type As.Dual 10gig LAN, ports, 10 nvme slots.... Stuff people don't need or asked for.
If it’s not overclockers Uk, he can’t post it here. So please don’t continue to ask when you don’t get an answer.With retailer you can buy for 425?
I spent a bit over the odds so as to get 10gbe LAN (need PCI-e slots for other stuff), enough USB-C ports for my usage and the PCI-e x16 slot latch (makes life so much easier if you change out the GPU much at all), amongst other features, was hard to find a board which combined all those which was also good value.
B860 level is labelled "mainstream"
giga bytes the dust has a long list of boards. by percentile of population these should as usual sell more units. (i mean non-highest end boards generally)
i'm ultra boring. of the less than a dozen boards i've had, ever ....i just stick with asus. because it is familiar over time to me.
i lapped a cpu once too. that actually worked. i sold the chip. the buyer didnt care it was lapped or not. so long as it worked."If you need to ask how much, you can't afford it"
Asus Maximus
