They do have one in the works, as it was shown off at the event where they released that power amp.I’d like to see a 25 GbE or a 100 GbE switch.
Id assume they should be seeing the light of day
Got a link? I think you mentioned this before and I tried to find some info but I couldn't.They do have one in the works, as it was shown off at the event where they released that power amp.
Nothing official, just from Reddit photos from the UniFi eventsGot a link? I think you mentioned this before and I tried to find some info but I couldn't.
I’m really hoping for a UniFi NAS
Should be fairly straight forward to add basic NAS functionality to the likes of the UDM Pro etc that has drive bays, then also have a full fat separate box solution.
As the 8 lite has a powerbrick, and the plug part is separate, they included a 3 pin uk plug to that smaller infinity symbol 2 pin small kettle lead.
Returning to this, as I said my Lite 8 switches, directly from Ubiquiti, both have a power brick with integrated two-pin EU plug.
I continued to query Broadband Buyer and they eventually said that they supply a "compatible" power supply with a UK plug (not clear if integrated or not).
Are you absolutely sure you have genuine Ubiquiti power bricks with a separate cable and not a third-party one?
I think something like the QNAP QGD-1602P would actually be ace, but annoying as I really fancied something like that but they were really hard to get.Should be fairly straight forward to add basic NAS functionality to the likes of the UDM Pro etc that has drive bays, then also have a full fat separate box solution.
Just seen an alert for one new product
UniFi Premium Patch Cable - Ubiquiti Store
Ultra-thin braided patch cable, designed and optimized for 10 GbE networking.uk.store.ui.com
Pretty sure my 8 port lite switch has a power brick with a detachable cable. Pretty sure it used a C5 connector. I didn’t have a spare one so I just used an adapter on the included EU plug.I will check tonight but I'm 99.9% certain the brick is genuine, along with he EU power cable that came with it, and they stuck a UK power cable in the box.
It has translucent boots though...~£10 for a 3m patch cable, come on now
Mine came with genuine brick in the box and extra uk lead outside the box.Returning to this, as I said my Lite 8 switches, directly from Ubiquiti, both have a power brick with integrated two-pin EU plug.
7 Bays seems like an odd number (although a much more useful number for e.g. RAID6).![]()
UNAS Pro - Ubiquiti Store
2U rack-mount NAS with (7) 2.5/3.5" drive bays and 10 Gbps performance designed for large-scale file storage and sharing.uk.store.ui.com
