scary how fast Intel is getting the underdog treatmentThese are the very same arguments AMD loyalists used to make when Bulldozer couldn't keep up with anything from Intel
who plays at 1080P these days? E-Sports players.
These are the very same arguments AMD loyalists used to make when Bulldozer couldn't keep up with anything from Intel, exactly the same arguments, those same people don't make those arguments now and Intel loyalists didn't make those arguments then.
ok so watched a few reviews, terrible performance vs lower spec CPU's that are from previous generationsHardly anyone jumping on ultra for obvious reasons, are you not looking at reviews?
But this is a new chipset, there will be bugs and this will be ironed out from updates and patches?>
I mean if someone wanted a new build they wouldn't get a 14th Gen CPU or the AMD 7950 series equivalent, no? because otherwise they would have bought this over a year ago
So would it be best to get a Ryzen 9950X, oh hang on there is no 9950X3D unless its coming out
I cant see any other Intel CPUs releasing anytime soon
Yeah, from what I've heard in the few reviews I watched, the 245K is pretty much just a productivity CPU, since the gaming performance is very inconsistent and not great overall.so if this stands for the new CPU's then the £290 245K is a 6 core CPU, with 8 accelerator's
its about 8% faster than a 14400f at about double the cost(in games)
I'm pretty sure that first part is not true, the E-Cores do have the necessary instruction sets to run games. How much they're used? That's a different question, from what I've seen 6 P-Cores or 8 P-Cores makes the E-Cores redundant in most games, but they are used effectively in something very CPU-dependent like Civ.EDIT: i just found this statment, its from the 13th/14th gen but i assume the same for new CPU's
E-cores are not used for gaming because it doesnt contain the necessary instruction sets. An E-core is not a CPU core because it cannot run a computer on its own. An E-core is an accelerator.
Not sure what you're looking at but I see the results being in line with each other baring slight differences for avg runs. The only more weird part is the beginning for 7800X3D (testing itself at all 3 resolutions) where for the first 6 seconds there's a 10 fps difference between 1080p vs 1440p which quickly resolves and the results track along the same fps (see image below). Didn't see anything out of the ordinary for 14900K results (at different resolutions), they track each other almost perfectly.Some weird goings on with hat benchmark, at 1080P the 14900K is 20% ahead, you would expect them to close up at 1440P, nope.... it flips with the 7800X3D now being 20% ahead, here's the kicker, there is little difference between the 1080P and 1440P runs for the 14900K, for the 7800X3D the 1440P run gets a huge boost in frame rates. To be clear the frame rates are much higher at 1440P than they are at 1080P.
This makes no flipping sense, this is the review you want us to trust? Its garbage mate....
When you're looking for something that looks to tell a different story to the consensus and you find it there is probably reasons for it other than everyone else is doing it wrong.
AMD made this market less of a cash cow with the release of 16 core mainstream CPUs. HEDT struggled on with Threadripper on and off over the years but Intel gave up largely.how comes there is no successor to Z299 LGA2066?
its got quad memory channels a high number of PCIe lanes and a lot of gamers and content creators use this platform but no successor and its been 6+ years
There's supposed to be a W890 coming, but if it follows W790 then it won't be affordable.how comes there is no successor to Z299 LGA2066?
right, ive given up on this platform anyways, now im stuck on choosing either 7950X3D on a X670E mobo or a 9950X with a X870E mobo or stay on Intel and get the 14th Gen on LGA 1700 or take a risk and get Ultra 9 on the new LGA 1851There's supposed to be a W890 coming, but if it follows W790 then it won't be affordable.
That's complete nonsense. They have instruction parity with the P-cores. That's why AVX-512 wasn't enabled in the P-cores as they had to have instruction parity. Otherwise the OS can't move threads from P cores to E-cores.EDIT: i just found this statment, its from the 13th/14th gen but i assume the same for new CPU's
I suspect that DFs video will do Intel a lot of damage. Deservedly so?On topic
I think their benefit is limited to mobile devices, with limited power and cooling.For me intel need to abandon the e cores idea it obviously doesn’t work
Lots of PC gamers still use 1080p monitors. My 2 brothers still do.a hell of a lot of people. and most of the competitive people
The newer AMD CPUs are definitely worth it for some workloads, if you use AVX512 the difference is pretty big.right, ive given up on this platform anyways, now im stuck on choosing either 7950X3D on a X670E mobo or a 9950X with a X870E mobo or stay on Intel and get the 14th Gen on LGA 1700 or take a risk and get Ultra 9 on the new LGA 1851
Big choice to choose from
very hard choice
www.pugetsystems.com
The point is still valid though, a CPU without them would likely be just as effective for gaming in the vast majority of games and better value.
