Caporegime
- 30 Jul 2013
I've not had any issues, so I'm going to say that's likely an instability somewhere with your system.Had to give up on this. Directx errors every 10 minutes or so in all modes.
loads of others have the same problem too.I've not had any issues, so I'm going to say that's likely an instability somewhere with your system.
Yep I'm still getting them dispite even reinstalling windows 11. Latest Bios etc.loads of others have the same problem too.
Ive got loads of other games to play so not to bothered, i''ll wait till they fix it in a few years maybe.Yep I'm still getting them dispite even reinstalling windows 11. Latest Bios etc.
My 7950X3D RTX3800 has never had issues on any games before and this is a widespread issue.
Sometimes you tweak a setting and it works for a couple of hours then out of the blue - freeze and Direct X error.
I don't know whats more frustrating the sweating or the freezing![]()
566.03Nvidia users, which drivers do you find best (and do they make much difference)?
Lower the game settings so you use as little vram on the graph it shows in the settings and it should be ok. I have a 3080 paired with a 7800x3d running at 1440p and since doing it I haven't had one crash with it on low and dlss on balanced. It's hardly noticeable the difference in graphics anyway.Yep I'm still getting them dispite even reinstalling windows 11. Latest Bios etc.
What I don't get is like last night I had about 8 rounds and all ok. It gave me the direct x error in the winners circle when I went to press a key to emote. The vram usage never goes above 70 and I cap the frames at 90Lower the game settings so you use as little vram on the graph it shows in the settings and it should be ok. I have a 3080 paired with a 7800x3d running at 1440p and since doing it I haven't had one crash with it on low and dlss on balanced. It's hardly noticeable the difference in graphics anyway.
I totally understand as it has crashed with me just starting the round as well as mid round. But after changing my settings I haven't had a crash in a week.What I don't get is like last night I had about 8 rounds and all ok. It gave me the direct x error in the winners circle when I went to press a key to emote. The vram usage never goes above 70 and I cap the frames at 90
Considering the 1080Ti seems to be on the GPU list for recommended spec I'm surprised how poorly this runs. Can't even get decent framerate at 1080p on lowest settings.
interesting, I have to play at 720p with low setting to get 120 fps.Running a Aorus 1080Ti. I'm on High details, everything is set high, running the Image sharpening as well. 1920x1200 @ 60fps.
Get the same myself. Only game which has this issue. I was on the fence with the engagement based damage, but I'm finding it hard to believe it's not a thing now.Does anyone get one game where your gun seems to kill fast and the next it acts like a pea shooter? I literally stood in front of a player absoloutely unleashing for them to smash you in a few bullets.
I play core nuketown 24/7 at the moment and the hit reg is crazy, some games are fine im convinced that skill based damage is around.
Im prestige 5 and have been playing a lot so can generally hold my own but some lobbies are crazy.
