@Cenuij this is what I've ended up with... basically stock EXPO with a few Buildzoid settings and decreasing tRFC as you recommended.
Not great, but I'm only gaming so I'm sure it's fine. I did get away with the -35 curve optimiser and some people can't do -20, so there's that I guess![]()
70ns in Aida is probably what I would expect from my own experience using that tool @6000
Have you tried 6200 with 2066 FCLK? 6200 is not too hard, and 2066 aligns nicely at 3:2
Edit: I guess also disabling gear down mode might eek out a little bit more performance, and then disabling bank address hashing would probably boost write speeds a bit.
