Hello everyone
Applying an oil-based stain block and then painting over did the trick! I hope this helps - I first applied the stain block using a brush but the final painted finish wasn't very good. Using one of those small foam rollers to apply a thin coat of stain block gave a much better finish.
Thanks again! R
I think you'll find that the room will get warmer but the columns won't, so you might be at risk of condensation/damp on them. It may help a bit though, possibly depends what the room is like at present (e.g. almost warm enough vs garage sort of temperatures)We've got a single skin brick side return and utility adjacent to our kitchen. It has 2 skin brick columns every 2m or so for structural support. It's absolutely freezing in there. I'm wondering if it's worth slapping some insulated plasterboard on the single skin walls? My main concern is that the brick columns won't be insulated, as it would protrude too much and make the passage too narrow. Would not insulating these columns render insulating the rest of the wall itself fairly pointless?
The outdoor tap cover came yesterday.
I'm normally on this sooner but I couldn't find it.
We had a new outdoor tap fitted last year as the other was .... Ropey.
Didn't realise an isolation valve was fitted.
So lunch yesterday. Tap off, water drained, cover on.
I think I'm winter ready now ....probably forgot something.
Going ahead with this, and adding a switched fused spur to each run just for some safety reassurance and individual isolation - just a 3A fuse in each.I currently have a wall mounted extractor in our en suite bathroom, which is not doing a sufficient job of getting steam out leaving us with condesation on the window, tiles and more recently the start of black mould on the ceiling - the wall mounted extractor is not situated in the best place for effective extraction, and only pulls 15l a minute.
I've ordered a Manrose 100t inline extractor unit to be put in the loft space which I'll use in conjuction with the above, which will vent out of an also ordered Ubbink UB41 with the pick up point being in the shower, with 60l a minute extraction rates.
Can I just cut the cable feeding the existing wall extractor, and Wago junction box the two extractors together off the same isolator? I can't see it being an issue given the relatively low loads involved.
Is there a reason to not use both extractors simultaneously off the same isolator?
I didn't think the picture was high res enough to see the booksLove a bit of James SA Corey, Expanse![]()
I didn't think the picture was high res enough to see the booksGreat series of books though
The TV series actually manages to do the books justiceThat particular series has unique cover art.... Also, I am reading it now so it jumped out at me. Just finished Book 6 so going to read the first 6 of the novellas from Memory's Legion, then go through Dragons Tooth before starting the last 3
After watching the TV series twice over, it's the series that got me back into reading books![]()
Could you share the list please? There must be something I'm not doingYesterday I printed a maintenance list, basic, item, tasks and months along the top, this is how cool I am.
Stuff like run the dishwasher with nothing in, clean the secondary filter, check spray heads.
it's stuff like this, which I think I do often, but its actually months apart.
I then did the above and added clean hoover filters to said list.
I always mean to do this as I also leave it too long between regular tasks. Anything with a routine - bins, cat litter, bathroom cleaning, like clockwork. Anything with a "frequent" or "periodic" category, I forget until it's a bit overdue.Yesterday I printed a maintenance list, basic, item, tasks and months along the top, this is how cool I am.
I dream of a list of annual tasks I can check monthly to stay on top of things.
