- 14 Oct 2007
- newcastle
The 9800x3d only has one CCDDoes the 9800X3D has a Dual 3D Cache Die?
which gpu will you be getting?Just got mine installed and going but that damn memory training had me thinking something was wrong and the motherboard stating a ram error code didn’t help.
All good though, roll on nvidias release!
It’ll be between the 5080 & 5090which gpu will you be getting?
I'm not buying this time so I can just sit back and laugh![]()
Would be nice if no one buys the 5090 due to price increase but not sure if that will happen!
They won’tearly talk is this time they 'might'
The 5090 pricing.Laugh at what?
Turn on Memory Context Restore in BIOS?Wouldn't care if they did tbh. Wasn't remotely tempted by the other 3D offerings last time.
Also not sure why but my pc takes 20x longer to boot up now than it did before. I see by the mobo led it's doing memory training but thought that was a one time thing.
The 5090 pricing.
2200 is not stable, try 2167. Aida latency should go down, if it goes up or stays the same FCLK needs to be dropped.Results of testing 2133 vs 2200FCLK at 6400CL28
2133
2200
TLDR
2200 FCLK yielded around a 25-30pts improvement in CB24 and about 60pts in Timespy. Very slightly higher latency in AIDA64(0.3NS) but higher R/W/C figures. The gains in Black OPS 6 were actually quite significant, improving average frames by 24fps, and the 1% lows by 10FPS. Of course that isn't really percivable at these high frames, but it's an improvement nonetheless and more than I expected to be honest.
After testing in Linpack Extreme, I did see some GFLOP dip, meaning that 2200 was unstable at my previous VSOC of 1.27v. I was able to lower the VSOC to 1.18v and Linpack GFLOP throughput now seems consistent. Will need to retest RAM stability again, but suspect it should be fine.
