I think your post had merit, this lad changes computer hardware and displays more often than most of us have hot dinners.hahahahaha ill believe you this time lol roll on january
Says Mr '50 4090's'I think your post had merit, this lad changes computer hardware and displays more often than most of us have hot dinners.
Need to try that for myself, dropping FCLK that hardMy chip/IMC is quite strange. At 1.27v, I was getting FCLK errors in P95 large FFT’s. That’s at 6400CL28 and 1:1 with 2200FLCK.
Dropping the VSOC to 1.17v stabilised the FCLK and the RAM stayed stable.
High FCLK does often need lower soc voltage to be stable, but I was quite lucky that the RAM stayed stable at a lower VSOC. I think I have a very strong IMC.
That being said, I would rather run 64001:1 2200FCLK with a 1.3 VSOC than 8000 2:1 with a low VSOC.
8000 is a flexy number, but outside of synthetic benchmarks and productivity, it’s not worth it. 64001:1 is consistently shown to outperform it in games.
To outperform 6400 1:1, you’re likely looking at 8400+
do you have the noctua offset bracket? if not grab it for for a cheap return on lower temps, it sounds like you may have backgrounds tasks running and therefor not really idle.Alright, I realised my Curve Optimiser wasn't stable. OCCT and everything else passed fine, but STALKER 2 crashes. Turn off CO, no more crashing. This means I just want to run the CPU at stock, but at stock my Noctua dual tower cooler runs in the mid 50s at idle, which is ridiculous. Does anyone have cooler suggestions that will fit in a Meshify 2 case?
what was it set to?Alright, I realised my Curve Optimiser wasn't stable. OCCT and everything else passed fine, but STALKER 2 crashes. Turn off CO, no more crashing. This means I just want to run the CPU at stock, but at stock my Noctua dual tower cooler runs in the mid 50s at idle, which is ridiculous. Does anyone have cooler suggestions that will fit in a Meshify 2 case?
STALKER 2 crashes even at -20.what was it set to?
do you know what the temps are around the time it crashes? what were the rest of your settings? I have PBO enabled +200mhz -30 curve x10 scaler. Was the ram expo enabled or just custom settings?STALKER 2 crashes even at -20.
Temps are fine with the undervolt - 70s when gaming. EXPO - yes. I have further confirmed that turning off CO fixes the crashing in this game. If it has to be less than -20 I cba to be honest.do you know what the temps are around the time it crashes? what were the rest of your settings? I have PBO enabled +200mhz -30 curve x10 scaler. Was the ram expo enabled or just custom settings?
What does scalar actually do? I have -30 CO, +200 MHz, have tried 10x, 2x and default scalar and they all seem stable and perform the same
9800x3d 5.6ghz overclock
overclocked to 8000 or is it an 8000 rated ram stick? I managed to get https://www.gskill.com/product/165/390/1723430443/F5-8000J3848H16GX2-TZ5NR running on it fine with just expo profile enabled and nothing else. But the board was overkill for me so I returned and swapped it for an msi tomahawk.After a couple of hours of toiling I finally manage to boot into 8000mhz on the X870E hero but no matter what I seem to change memtest errors out after a few minutes so I think ASUS needs to sort out the bios, even the 6000 preloaded profiles wouldn’t boot and had to start from scratch just to get that speed working.
If you see my post above on the same page, I think I solved it. Running OK temps now.
Are you by any chance using a 'thermal paste guard'? I expect what might have happened to me is that this came loose and covered the CPU as I installed it. When I took the DH15 off, the AM5 guard was at an angle.
Might be worth a check! Or this had nothing to do with it... and it was the re-seat that sorted it.
