Caporegime
- 18 Oct 2002
When HU sorts out the spanish version we can see what their take is on charging for cards related to their vram.
We kinda know they've upped the price and push the cards one tier up, so the 4060 is effectively a 4050. Looking at it like that, 8GB is not necessarily crap and unplayable. Devs know the 8GB problem and not doing something to improve it (like Direct Storage and better overall memory management and settings options), is sloppy. Even more so looking back at older cards.Bit contradictory old bean, you say its been talked to death and its sloppy dev work and storage techniques to why.
Then you mention features like FG that take up vram, and say 16GB on the 5080 will probably be problematic.
Its pretty simple when nvidia are commanding high premiums for their products the vram should be ample - not just about enough or it should do for most game scenarios...
Sure I'll like 20GB for the 5080, but I'm not that willing to spend extra $200-$300 for it in case I may need it X numbers of years later. nVIDIA won't give it away cheap!![]()
'It wouldn't be an issue if it had enough in the first place'When HU sorts out the spanish version we can see what their take is on charging for cards related to their vram.
Oot the window, it's evolved into 'just turn off the RTX'just turn down the settings
And basically turn your Nvidia card into an AMD one'It wouldn't be an issue if it had enough in the first place'
Steve and Tim's just debunked all the excuses in the locker there, even showing a highly tuned CP crippled with RTX on...
but....
Yes just turn down the settings, lol remember this well!
It's funny how his solution is still 1080p, but with better AA. And as a quick example, Stalker I think is only UE 5.1, not 5.5.Explaining pretty much what the majority of us think.
Modern graphics are unoptimized trash and it all started with RT.
I do not think its trash but it certainly isnt worth the hit. The main issue is the entry to mid cohort of the dGPU's have always struggled - hence the reason it has got some attention referencing the HU video.
If you are able to sport a 4080 or better calibre card then your in good territory. The other point people make is the game itself and particularly optimisation, so many fail getting this over the line that no wonder its not been warmly received.
FG delivering 60fps@1080p running low settings using DLSS@quality with RTX ON, canny wait!
Certainly isn't the holy grailIndiana Jones and the 'It's Barely Better Than Raster But Halves Your FPS'![]()
It's a bit strange as the 7700XT is not as fast as a 3080TI
