Deleted User 298457
Deleted User 298457
Titan vacuum switch chaps?
I’m not sure what you are trying to achieve? The connections should be inside the lights which themselves should be IP rated if they are for outside, you shouldn’t need any further waterproofing.
Edit: might need a picture of the issue to give any advice.
3D printed a bunch of gutter hooks then went outside and fitted all the christmas lights to the house![]()
This is what I mean - it could be down to my ineptitude, but I've two twin and earth cables coming out the wall, how on earth am I supposed to get them both back fed in to the sealed box (opposite side to the bulb holder wiring) easily? The second fitting with a single cable was just about manageable, but coupled with the fact I hate chocolate block style connectors too I'd rather go the Wago route and side feed in to one of their gel boxes if this fits....
Your plan is sound and these work well for exactly this. I’ve had to fit customer-supplied lights of even worse design before and these gel boxes saved the day, tucked in the back of the light fitting. Wiska also make an equivalent version which are the ones I’ve used.I was thinking of using it instead of the box they come with, for an easier more secure connection
Not sure what is usual but mine is a 90mmI'll need to give this a go sometime, my flat shower chrome bit is badly tarnished - from what I can gather these are usually just standard 2" holes rather than specific to the tray?
Perfect, thank you it's good to know my thinking is sound, Just to size up what gel box will actually fit in them then I'll get ordering.Your plan is sound and these work well for exactly this. I’ve had to fit customer-supplied lights of even worse design before and these gel boxes saved the day, tucked in the back of the light fitting. Wiska also make an equivalent version which are the ones I’ve used.
