- 11 Jan 2007
- *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
Another update? 10.99gb.
What res/settings are you playing at?Plays well on my 3090 and game pass.
My guess is vram.
4k dlss balanced + Frame gen ON. Epic settings. Also using mod to improve LOD and get rid of trees/grass popping in which shaves off about 10-15fps.What res/settings are you playing at?
Sweet, thank you. I'm on a 5800X3D/3090, and you don't have much latency issue with frame gen on?4k dlss balanced + Frame gen ON. Epic settings. Also using mod to improve LOD and get rid of trees/grass popping in which shaves off about 10-15fps.
oh this is awesome! I just spent a tense hour in the zone, its the music the worrying about running straight into an anomoly or a bunch of dogs.. sneaky sneaky, high radiation, hungry....![]()
S.T.A.L.K.E.R. 2: Heart of Chornobyl - Patch 1.0.2 is here! - Steam News
New patch that will make the Zone even better place.store.steampowered.com
A few more fixes.
I had latency until I added 2 lines in input.ini then all fixed:Sweet, thank you. I'm on a 5800X3D/3090, and you don't have much latency issue with frame gen on?
Edit - sounds like Nukem's dlssg-to-fsr3 mod is a good solution to any possible input latency issues.
[/script/engine.inputsettings]
bEnableMouseSmoothing=False
bViewAccelerationEnabled=False
Not a good start to the update..
I had only one crash after 16+ hours, but got this after less than a minute![]()
It should do, was night and day for me. Are you sure you updated the right file? Steam version is in a different folder to gamepass version.Tried that. Made no difference.
I'll put this game on gold till I get a new GPU
Couldn't agree more. I've got so many stashes all over the place with that sort of stuff in.Anyone else finding the game too easy after a while? I have so much food, med kits and bullets saved up that I'm starting to consider selling half of it.
I've upped the difficulty to veteran and just slaughtered a whole swarm of different mutants with relative ease.
Quite surprised at how relatively easy it is considering Stalker game's reputations.
