AMD Ryzen 7 9800X3D
  • Thread starter Thread starter Hostile_18
  • Start date Start date
Had no problems with my CPU on stress tests using CB23 and playing COD for few hours
But the new Fortnite is causing my system to crash
Playing games the CPU temp is 73 and CB23 stress test after 15 mins is 88 so doesn't appear to be a temp issue
As a quick check CB might be okay but to stress the cpu I’d use something else like prime95, OCCT and the like
redid my loop to add in my 9800x3d.. using an AC Core1 block and QDC.. quick light overclock PBO enabled, +200, -40 scaler at x10. Haven't started playing with memory timings.. not sure how much there is to play with, with a 64gb kit
Let the CPU run in before i start delidding it.
Do you enable the X3D Turbo in the bios or leave that disabled?
I've ran a few tests and with it enabled the scores are significantly lower.
I left that disabled. Not tried enabling
Thanks for the reply, my 9800x3d with same PBO +200mhz, -30 scaler at 10x will only hit clocks of 5,415.2mhz.
Perhaps I've not been lucky on the silicone lottery.
Seems stable running a CB24 for 10 mins+.
Temps max out at 82c on CB24.
Idle is mid 30c and gaming mid 50c.
Starfield on ultra, 1440p.
F5-8000J3848H16GX2-TR5NS.​
I've gone for a 2x24 so it's a bit more future proof for capacity but def 32gb is for max perf.
do they come with multiple expo profiles? just curious as the ones i do did. not that i use them but just thinking as a base speed its kinda helpful to work from. im looking at the same kit but 6400
Yeah, there are some profiles, but I've never used them as I do it all myself.
Dot in the middle, job done. A pea sized dot will be too much for this size of chip
I’m sure there’s been various different methods used on here though
Thanks. I asked because the CPU isn't a regular shape so wondered if the paste would spread across the whole surface.
That will probably be down to BCLK not being at exactly 100, try setting bclk manually and disabling spread spectrum.
