no.. mines MSI this time. Spec in signatureI might be wrong, but that sounds like an Asus thing to me, is it an ASUs board?
I Refuse to buy Asus boards now, for this very reason.
In your profile there should be a tab called stock notifications where you can turn it off.I signed up for stock information alerts on the 9800X3D. Is there any way I can opt-out until the price is back to normal? Not interested in buying it at the jacked-up price
Thanks MikeIn your profile there should be a tab called stock notifications where you can turn it off.
Don't think there's a price tracking alert.
9800x3d is a gaming cpu for productivity use you look elsewhere Steve even made that perfectly clear on the GN benchmarks never mind HUB no-one is suggesting otherwise. Intel fans fret ye not your 14900k's are safe for another day.Bucket of cold water time.
The average gamer will not notice anything if they swapped between a 14900K and a 9800X3D.
Those are games configured as a cpu test and not games in a configuration likely for a £2000 gpu and a £500 cpu.
Behold:
12.6% difference at 720p Ultra
7.2% difference at 1080p Ultra
4.1% difference at 1440p Ultra
1.1% difference at 2160p Ultra aka 4K
Then there's work workloads, a 9800X3D does not beat a 14900K in most things.
Game benchmarks on low settings are simply a cpu test that favours 9800X3D. They absolutely do not mean you keep that performance advantage outside those settings.
Normally the caseSounds like a classic case of PEBKAC my friend.
Do you ever hear from Gregster these days?
I've had issues with mine. 9800x3d and 64Gb Corsair 64GB (2x32GB) 6000MHz CL30 (not on the with a cheap Asus B650 Tuf motherboard. Set it all up last week (just enabling EXPO but no CPU OC) and it was totally stable for nearly a week, no issues whatsoever. A few days ago the machine just started rebooting randomly after half hour or so and immediately if doing any sort of memory stress test. Everytime it rebooted the DRAM light on the mobo came on for a while and it looked like it was retraining the memory. I had upgraded from Win10 to Win11 a few weeks before changing the hardware over. After some support from awesome folk on here we suspected it could have been a Windows issue as ram testing and stability testing outside of Windows was fine. Did a full reinstall last night and everything currently looks stable so will see how it goes. Its probably my fault because the ram kit I got isnt on the certified list of supported memory for the motherboard (though I have never had to in the past buy a certified kit), you could also argue I cheaped out on a B650 motherboard.Is it my imagination or do there seem to be an unusual number of people having problems with RAM and the 9800X3D??
Because it's a CPU test not a GPU test, they're testing the CPUs and trying to not have the GPUs get in the way.
The 9800X3D will also offer better 1% lows so the overall experience will be smoother.
Obviously people not running the best GPU won't need the best CPU but I don't think anyone's said otherwise. HUB also recommend upgrading your GPU and sometimes even your monitor before your CPU.
The only contradiction to this is the currently few CPU heavy titles, or simulation games which don't depend on framerate but the time it takes for the CPU to calculate what the AI is going to do.
If the stability problems come back I may have to look at switching the motherboard to something a bit better and make sure I get a verified ram kit.
I'm hoping stabilty will improve as the platform matures and newer bios are released.
I think CPU benchmarks are misunderstood.But what they have done is hyped up a processor to the point where many gamers want only that processor, when in fact that's probably not even the bottleneck in their system. It's a bit like selling tyres tested in Siberia to people in the Bahamas. The reason that I think they are doing that is because they are answering the wrong question. People don't just want to know which is best, they want to know which they will see a real-world difference with. They should run the tests, even if the tests show no difference.
Much as I generally like HUB, I have to admit I can't see why this was necessary. We all know the 9800X3D murders the 14900K, did we really need yet another video on the subject?
Does feel like HUB over-do it with the benchmarks and comparisons sometimes.
They are not saying "9800X3D is x% better than a 14900K, you should buy one", but rather demonstrating the maximum frames that a given CPU CAN generate.
By dropping to a lower resolution you are removing the GPU as a performance bottleneck and moving that performance limitation to the CPU. If in a given 1080P test a 9800X3D can generate 250FPS but a 14900K can only generate 180FPS, then regardless of GPU choice you will never get more than 180FPS out of a 14900K. If at 4K your GPU can only push 150FPS then of course it doesn't matter whether you have a 9800X3D or a 14900K (or even something less performant) driving the frames, but once faster GPUs become available, e.g. one that could run the same game at 200FPS in 4K, then the 9800X3D-based system would demonstrate a clear lead over the 14900K, which will still only push 180FPS.
In general terms, people (even enthusiasts) tend to upgrade their GPUs way more frequently than their CPUs, so buying decisions are much more about the future performance potential than the difference they give right now.
I think out the box just enabling expo would give a hassle free uplift. Other than that PBO but it does need a bit of a fiddle and testing from what I’ve seen for it to get stable.Is there anywhere that has posted a nice simple settings to get decent performance out of the 9800x3d without spending all day testing?
I just followed a cookie cutter setting I have seen several people mentioned. I tested with 10 minutes of Cb23 and 1 hour of Occt and of course games playing.I think out the box just enabling expo would give a hassle free uplift. Other than that PBO but it does need a bit of a fiddle and testing from what I’ve seen for it to get stable.
Although stability will depend on what program you use and are happy with
Mine boots and benchmarks with a PBO of -40, scaler of 10x and +200Mhz but stressing is certainly another storyI just followed a cookie cutter setting I have seen several people mentioned. I tested with 10 minutes of Cb23 and 1 hour of Occt and of course games playing.
curver optimiser at -30, core boost overide +200 (optional), 1xscalar. A majority will do -30 but if not -20 is doable for nearly all 9800x3d samples. An if you are really really unlucky -15/10 should cover all. I used that for quite a bit. But mine can do -35. I have seen a few that can do -40.
