- 25 Aug 2008
- York, UK
I did the same, I have an ethernet connected to my playbar and all has been good ever since
Was anyone else under the impression that Sonos Voice control was all processed locally? This morning Gus Fring advised me that he couldn't check how long was left on my timer because he couldn't reach the internet.
Your request is processed locally on your Sonos product. Your audio data is not recorded, transcribed, or sent to the cloud.
I listened to both and couldn’t really tell the difference.Have any of you guys who own the arc ultra upgraded from the old arc? - I don't fancy doing a whole refresh of the current system (1 arc, sub and two SLs) without it sounding much better..
I've got plenty of ethernet cables. What do I do?Have you got a network cable to connect to any of them so they can create their own network to all connect to? That solved all my issues.
Have you true play tuned them in the new room?Just moved home and the Sonos kit is REALLY struggling in the new room. I used to set the subs at -2 but now having to set them at +4 to even hear them.
Both in opposing corners as before.
Much bigger room now though and it’s an open plan living/diner/kitchen.
Plug it into your speakerI've got plenty of ethernet cables. What do I do?
, other end to a router/ap etc.Cheers mate, I am struggling with so many films coming on DTS-MA these days, so may move my sonos to the family room, and get a full separate system for the man cave, this has helped me make a decision cheers!I listened to both and couldn’t really tell the difference.
Not like the difference in soundstage going from Beam to Arc.
IMO this is a new gen Arc with a new price tag, and a name to hide the fact it’s a price increase.
It isn’t a different tier of product.
yes, I have. It’s not a big difference really, speech is noticeably clearer and bass is much stronger. If you have the sub already I doubt the bass bit will matter so IMO only really worth it if you’re having problems with vocal clarity.Have any of you guys who own the arc ultra upgraded from the old arc? - I don't fancy doing a whole refresh of the current system (1 arc, sub and two SLs) without it sounding much better..
About time, fingers crossed the next person moves the company forwards not backwards.![]()
Breaking: Sonos CEO Patrick Spence steps down after disastrous app launch
Last year’s app debacle has finally led to Spence’s ouster.www.theverge.com
